  Power Lost After Changing Battery
Author Topic:   Power Lost After Changing Battery
striper swiper posted 06-09-2009 11:12 AM ET (US)   Profile for striper swiper
Changed the batteries, engine starts, buy I don't have power to the accessories, lights, radios, etc. Any ideas?
jimh posted 06-09-2009 11:22 AM ET (US)     Profile for jimh  Send Email to jimh
One of the blessings of electricity is its adherence to the laws of Physics (most of the time). Current flow requires a conductor. If no conductor exists, current cannot flow. Check your wiring.
striper swiper posted 06-09-2009 11:38 AM ET (US)     Profile for striper swiper
Jim, you mean the battery?
jimh posted 06-09-2009 11:58 AM ET (US)     Profile for jimh  Send Email to jimh
No, the battery is clearly fine since it can start the engine. Perhaps you omitted a connection at the battery. If something was working, and a change is made which produces a different outcome, go back to the change. Look for something as the cause.
Clearly mark all cables that attach to the battery so that your know which terminal they connect to and what their function is.
striper swiper posted 06-09-2009 12:01 PM ET (US)     Profile for striper swiper
I took digital pics before and matched to after..but they may have been wrong in the first place, but I do recall all electronics working last season.
Peter posted 06-09-2009 07:55 PM ET (US)     Profile for Peter  Send Email to Peter
The engine has its own battery cable. The boat has its own battery cable that provides the house power. So you should have at least two positive and two negative cables attached to your battery (assumes a single battery system). Because the "house" power is said to be non-existent as evidenced by the fact that all of the accessories are not operational you probably have 1) not connected the house battery leads to the battery or 2) have a blown main fuse or a tripped circuit breaker between the battery and the house power distribution bus.
jimh posted 06-09-2009 09:44 PM ET (US)     Profile for jimh  Send Email to jimh
To search for your problem:
--Begin at some point where you expect to have voltage
--Measure the voltage at that point
--If there is no voltage, follow the conductor back toward the source of voltage until you find the discontinuity.
To perform this test you need:
--a voltmeter
--the ability to check voltage with the voltmeter
--the ability to visualize the circuit and follow the conductors
If you do not have this ability, you will have to hire someone who can perform electrical diagnosis and troubleshooting.
pglein posted 06-10-2009 06:46 PM ET (US)     Profile for pglein  Send Email to pglein
Take a piece of paper down to the boat. Create a map of all the wires...every single one...noting the type, size, and color of all the wires, as well as the connections. Pictures in addition would be helpful. Then, scan and post the map and pictures into this thread.
That is about the only way we could possibly help you diagnose this problem.
If you changed batteries, and everything worked ok before, but does not work now, I'd be willing to bet that you connected something incorrectly at the battery. There are usually only three or four wires that connect to the battery. It should not be difficult to determine if one is not in the correct place.
pglein posted 06-10-2009 06:48 PM ET (US)     Profile for pglein  Send Email to pglein
Note that, if at any point while disconnecting or reconnecting the battery, you experienced a spark or flash, it is likely that you blew some fuses or fried some electronics.
striper swiper posted 06-11-2009 04:11 AM ET (US)     Profile for striper swiper
I will take pictures and post them in the morning..if it ever stops raining.
striper swiper posted 06-11-2009 07:55 AM ET (US)     Profile for striper swiper
Here are some photo's of the batteries and a view inside the console, I hope it leads to a clue.
http://www.dotphoto.com/GuestViewAlbum.asp?AID=5875472
jimh posted 06-14-2009 01:38 PM ET (US)     Profile for jimh  Send Email to jimh
Is there any follow-up on this problem?
striper swiper posted 06-14-2009 03:12 PM ET (US)     Profile for striper swiper
Yes. The problem is the ETA 50 amp breaker part #41-3S14-LN2. I will order the same part and that should do it.
