  Sahara Bilge Pump With Integral Float Switch
Author Topic:   Sahara Bilge Pump With Integral Float Switch
BBS posted 08-03-2009 04:24 PM ET (US)   Profile for BBS   Send Email to BBS
Can a Sahara bilge pump with internal float switch be repaired? Or, should I just install a new bilge pump? I am not exactly sure what the problem is. The Sahara bilge pump with integral float switch will not turn on when there is water in the bilge.
jimh posted 08-03-2009 08:35 PM ET (US)     Profile for jimh  Send Email to jimh
Before discarding the existing Sahara bilge pump with integral float switch, verify that there is a good power feed to it.
To determine if the Sahara bilge pump with integral float switch can be repaired, check with the customer service representative from Sahara. Generally a small and inexpensive plastic pump cannot be effectively serviced.
