ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Garmin Releases New Planning Software
Author | Topic: Garmin Releases New Planning Software |
bluewaterpirate |
posted 10-02-2009 04:02 PM ET (US)
Guys--You going to like the new Garmin Planning Software, and here's why. You can download your exisiting G2 Charts from your 400/500/4000/5000 series to an SD memory card (min 4 gigs, strongly recommend 8 gigs, so you have room to add and save waypoints, routes, and tracks from your unit and Homeport). Once your G2 Charts on downloaded to the SD card you can then upload them into Homeport for use in planning trips and adding waypoints, routes, and tracks. This means there is no more requirement to purchase Map Source and the BlueChart CD; you already have all the charts you need on your chartplotter. Once you're finished building to you chartplotter. There are some really nice features in the new software. Cost is $29.00 You can download it from the Garmin Website. https://buy.garmin.com/shop/shop.do?pID=64242# Here are some of the features: --displays both fishing and navigational charts from BlueChart g2 Vision --allows user to measure distance and bearing on the charts --displays route/track depth profile --converts tracks into point-to-point routes (track to route conversion) and specifies the speed for each leg of the route --provides ETA and arrival times (for each leg) when you create routes --shows animated playback of data collected on device --calculates fuel consumption (based on fuel flow data provided by the user) --exports selected data to Googleâ„¢ Earth --displays statistics and graphical information about tide stations, tidal streams and currents --displays grid lines to show latitude and longitude --allows you to manage waypoints, routes, and tracks --allows you to view the map north-up, map-up or course-up --displays celestial information such as sunrise, sunset and moon phase --displays photos and point-of-interest detail --supports vector charts --includes worldwide basemap --allows multiple map views Tom |
Waccamaw Whaler |
posted 10-03-2009 12:14 AM ET (US)
According to the web site the HomePortâ„¢ software doesn't support the 545s which I thought you owned. Do you know any differently? I emailed this question to Garmin also. |
bluewaterpirate |
posted 10-03-2009 09:33 AM ET (US)
It supports the 545 with the new update V5.0. I'm running a beta version of the software. |
Waccamaw Whaler |
posted 10-03-2009 10:21 PM ET (US)
Let us know if you think the program is worth the $29. In that you recommended the 8GB SD card I assueme it works in the 545s. I ask because when I first received the unit I called Garmin about the recommended size of the SD card and I was told 'no larger than 2GB' This is the 'regular' size vs. the MINI SD card - right? Ron |
bluewaterpirate |
posted 10-03-2009 10:49 PM ET (US)
Ron ...... One of the previous updates gave the 545 the capabilty to handle 2 gig SD cards and above. I'm using an 8 gig SD card. Have you done all the updates .... your missing out for sure. |
Waccamaw Whaler |
posted 10-04-2009 03:15 AM ET (US)
Yes Tom, I have the 5.0 update and agree it has great new features. I missed the ability to use the 8 GB SD card though. I'm also still trying to understand what the "White Line" feature is indicating. Just as I think I know, something changes to raise another question. I take it you are recommending 'HomePort' from what you've learned from the beta version so far? |
bluewaterpirate |
posted 10-04-2009 01:28 PM ET (US)
Absolutely .... if you don't have Map Source it's a bargin for sure! Here's a link where I explained it all. Most of new functions in the updates Garmin is making are from inputs from their users. Tom |
Waccamaw Whaler |
posted 10-06-2009 07:38 PM ET (US)
Tom, I was just getting ready to order an 8GB SD card off of ebay so I would have it to download "Homeport" when it becomes available Nov. 1st. However, I have a concern that I may order the wrong card. When reading through the internet I came to the conclusion that the 8GB cards are referred to as "SDHC" vs. "SD". The e-bay ads indicates: Although identical in size to today's standard SD card, the new SDHC cards are designed differently and are only recognized by SDHC host devices. To ensure compatibility, look for the SDHC logo on cards and host devices (cameras, camcorders, etc.)." [My concern] Do you know if the "SDHC" will work in the Garmin 545s? Also, I found the cards are rated at different speeds i.e., 2, 4 and 6 with 6 being the highest speed. Do you know what your card is or what Garmin may be recommending? Ron |
bluewaterpirate |
posted 10-06-2009 08:04 PM ET (US)
Ron ....... Here you go ...... video http://bluewaterpirate.phanfare.com/4327860_4779163#imageID=82613618 Tom |
Waccamaw Whaler |
posted 10-07-2009 05:39 PM ET (US)
Tom - a very helpful video as all of yours are, Thank you. You didn't specifically mention anything special about the 8GB card so I'm assuming that any card that fits the Garmin slot, i.e. the same size, regardless of the speed, will work OK? Ron |
bluewaterpirate |
posted 10-07-2009 08:05 PM ET (US)
That's correct Ron. |
Chuck Tribolet |
posted 10-07-2009 09:57 PM ET (US)
SD and SDHC cards use the same electrical interface. But the addressing is different. SD cards were byte addressed, SDHC cards are sector (512 byte) addressed. They ain't the same. - My IBM-issue Lenovo ThinkPad T61p was quite happy with SD Net: borrow a card and try it BEFORE you open the package.
Chuck Tribolet |
posted 10-07-2009 09:59 PM ET (US)
Reading BlueWaterPirate's original post: "min 4 gigs .... strongly recommend 8 gigs" it's highly likely that SDHC is supported. |
Waccamaw Whaler |
posted 10-09-2009 04:50 PM ET (US)
At Chuck's suggestion I contacted Garmin and got a very quick response. Tom, I'm curious as to your response.
Thank you for contacting Garmin International. I am pleased to assist you. Why would you want to use an 8 gig card? [comment deleted] You can download the preloaded maps from your 540 to work with them on the PC. The maps require 911 MB. That leaves more than enough room to store all of the waypoints, routes and tracks that the 540 could possible hold. That means a 1 gig card will suffice. You can only view g2 Vision cards in Homeport using an SD card reader. You cannot copy Vision cards. Having said this, the largest card we have tested in the 540, here in product support, is a 4GB. I have not seen any brands that do not work. As I understand it, any card larger than 2 gig is an HC card. You do not Please let me know if there is anything else I can do for you. Michael H |
bluewaterpirate |
posted 10-09-2009 06:15 PM ET (US)
Well Ron ...... Michael at Garmin just had safe sex with you. You see the 8 gig card in my video that's what I copied all my data to and it works just fine. I used a 2 gig to start with and I got and error message saying insufficent memory Go do what you want. Enjoy .......... Tom |
Waccamaw Whaler |
posted 10-10-2009 10:56 AM ET (US)
Tom, I assume your card is marked HC. You mayjust be a step or two ahead of Garmin on the card capabilities. My inclination is to get the 8GB - I just want to make sure I get the right one. Ron |
bluewaterpirate |
posted 10-10-2009 01:32 PM ET (US)
It is and hc card runs like a champ .... sorry I was in a foul mood last night. |
Waccamaw Whaler |
posted 10-28-2009 07:18 PM ET (US)
Tom, I downloaded HomePort onto a new 8 gb '2' Sandisk SD card I just purchased. I haven't had it on the boat yet but it appears to be working OK on the desktop computer. I have the program on my 'C' (hard drive) in the Program Files/Garmon. When I click on the icon to start HomePort the program opens and runs fine. What is strange and a bit annoying is that the computer tries to access my 'A' (floppy drive). The 'A' drive indicator light stays on the whole time the progam is open and the drive keeps clicking as though it is reading the floppy. As soon as I close Homeport it's back to normal. Did you have this experience? Ron |
Chuck Tribolet |
posted 10-28-2009 08:17 PM ET (US)
How many people still have a floppy drive? I've got a USB floppy SOMEWHERE around here, but I haven't needed it in a couple of years. Last time was build a DOS system to get imaged onto a bootabel CD-ROM to upgrade the BIOS on my server farm at work.
Waccamaw Whaler |
posted 10-28-2009 11:06 PM ET (US)
Chuck, like you, I don't know when I used it last but I have dozens of floppy discs that may have some 'good stuff' on them & I might need it someday. Beside it fills what otherwise would just be a hole in the front of the computer. Ron |
bluewaterpirate |
posted 10-29-2009 09:20 AM ET (US)
What version of Windows are you running? |
Waccamaw Whaler |
posted 10-29-2009 11:55 AM ET (US)
Windows XP Professional |
bluewaterpirate |
posted 10-29-2009 12:28 PM ET (US)
XP sees your floppy reader as an external data source. Put a disk in it before you open HP. HP will see the disk and the data on it but not open it. Your drive should shut down at that point. Tom |
bluewaterpirate |
posted 10-29-2009 12:29 PM ET (US)
Here are some videos I've done in regards to Homeport. http://bluewaterpirate.phanfare.com/4399275 Tom |
Waccamaw Whaler |
posted 10-29-2009 09:55 PM ET (US)
Tom, that worked. The indicator light still stays on the "A" drive but it's no longer trying to be accessed. Thanks. Another question, have you been able to add a new waypoint and then change it's properties. When I add a waypoint the only symbol that shows is a gold anchor. I have tried to change it's properties via the 'file' route and also the mouse buttons. No luck? I'm very familiar with MAPSOURCE and can change properties with no problem. I suspect HOMEPORT is supposed to function the same re. changing properties but it isn't working for me. BTW, so far so good with the 8GB SD card. Ron |
bluewaterpirate |
posted 10-29-2009 10:27 PM ET (US)
The properties area is located below the chart area. You can point the bottom of the chart area and move it up to use the properties area. Tom |
Waccamaw Whaler |
posted 10-29-2009 11:16 PM ET (US)
Got it. Thank you again. I don't know how you found that. I fooled around for over an hour and never hit on it. I'll be on the water tomorrow. I'm anxious to see if the 5.1 update functions and see the tracks etc. on HomePort when I get back. At first I thought HomePort was a waste but now that I'm beginning to learn more of it's capabilities I think it's more than worth the $30. Thanks again Ron |
Waccamaw Whaler |
posted 11-06-2009 02:36 AM ET (US)
Tom, I inadvertantly deleted all of my waypoints, routes etc. from my SD card. I have all the data backed up on both HomePort and Mapsource and can easily transfer data back and forth between these two programs. However, no matter what I try I cannot get the data back on the SD card and into the Garmin 545s. I thought there might have been a problem with the SD card but I am able to record tracks and waypoints on any of the 3 cards I have. Can you suggest how I can recover the data? Also, with one of the recent downloads a 'tape' feature was added which displayed the position at the top of the screen. I had that feature then lost it. I tried downloading the update and running it again but it still doesn't appear in the menu or display. Thanks Ron |
bluewaterpirate |
posted 11-06-2009 02:42 PM ET (US)
Here you go ...... transferring wpts/rte/tks to SD card from HP or MS http://bluewaterpirate.phanfare.com/4399275_4822138#imageID=84429303 Compass Tape .... From Chart Display press the menu buttom > from the new menu select Data Bars > you will see the Compass Tape selection at the bottom of the new page. Tom |
Waccamaw Whaler |
posted 11-06-2009 07:32 PM ET (US)
Tom, I don't know if my connection was interrupted when I opened your video or if your video is incomplete. The video cuts off and returns to the beginning right after you insert the SD card and say "...it's going to recognize" I tried to open it several times and get the same thing. It also starts immediately as if it's stored on my computer? Ron |
Waccamaw Whaler |
posted 11-07-2009 01:47 PM ET (US)
I got the data transferred and the tape to show. I was doing everything correctly except 'selecting' DATA when it got to that point. After all the time I spent trying to figure that out I won't forget it again. |
Liteamorn |
posted 11-12-2009 10:31 AM ET (US)
Hi Tom I downloaded Homeport on my laptop and installed my maps on an 8gb sd card. I thought I would get all my existing waypoints and routes on my card when I installed but but Apparently I only uploaded the charts. (I have a 545s with the new update). I'm going to go down to the boat later to see if I can get all my existing added information on my chart. Do you know off hand if I can get this information on my card? Your videos are amazing and a huge help, words cannot express my gratifaction to you for all the trouble you go through to keepo us informed about our Garmin equipment. Ed |
Waccamaw Whaler |
posted 11-12-2009 06:32 PM ET (US)
Ed, I'm sure Tom will respond but for a quick answer you CAN transfer all of your data. I have transferred mine back & forth but I still don't have the process down well enough to be able to describe it to you. Since doing this and downloading the latest Garmin files I have had a problem with my SONAR display. I am getting about a 3/4" band of distortion on the right side of the screen. This is seperated by a very thin white line. Other than that the sonar appears to be working fine. I checked the transducer and it't tight and hasn't moved, it's not damaged and it's clean. Garmin techs are trying to determine if it is hardware or software problem. I get the feeling they think it may be software. If you encounter anything like this let Garmin and me know. Ron |
Liteamorn |
posted 11-12-2009 07:27 PM ET (US)
Thanks Ron, I have a problem with my card or my Garmin, I went back down to the boat and tried to download the user data (the instuctions are now on the online manual for the unit) and I get the message "can't write to card". I tried formating the card by turning the unit off, insert the card and power up the unit. I do not think this worked and that might be the problem. I do not have a white line problem on my sonar. Tom, am I missing something on formatting my card? That little bit of information I can't find on the manual. |
Waccamaw Whaler |
posted 11-12-2009 09:52 PM ET (US)
Ed, I assume you were using MAPSOURCE before you got HomePort. If so, did you copy your Waypoints, Routes & Charts from MAPSOURCE and paste them on the HomePort screen? Open both programs at the same time and it's a simple operation. At least that's how I got started. Be sure you have your MAPSOURCE data backed up so yo don't lose your base. Also, the biggest problem I had was when I selected TRANSFER DATA, on the GArmin, I didn't realize that I had to highlight and "SELECT" DATA when it got to that point since it was the only option that came up on that screen. Unfortunately it's a real pain running back & forth to the boat to see what progress you made. Ron |
Liteamorn |
posted 11-12-2009 10:53 PM ET (US)
Ron, I never even thought about my Mapsource software on my computer downstairs. I had all of my waypoints (sans this years new hotspots)on it. I transfered them to my card and from my card I as able to see them on my new Homeport software on my laptop. Now that my card has a place to put waypoints maybe I can add this years on the card too. Thanks! Ed |
Chuck Tribolet |
posted 11-13-2009 08:41 AM ET (US)
I suspect that Homeport can read the .gdb files that Mapsource wrote without playing games with a card.
Waccamaw Whaler |
posted 11-13-2009 04:19 PM ET (US)
Chuck I suspect you're right but I often take the awkard route not knowing any better at the time. Just as a follow-up on my sonar distortion problem, Garmin told me to download and install the latest 5.20 chartplotter software to see if that corrects the problem. I had already installed it but I'm going to do it again just to be certain. If that doesn't work they want the unit back for repair. |
Liteamorn |
Ugh, so in an attempt to aquire this years fishing spots I deleted the information on my sd card. I went down to the boat with my laptop, card reader and of course my card. I put my card in the machine and powered up my Garmin 545s. I then tried to copy my maps and hopefully my tracks, routes and waypoints. I got the message "Cannot write to card". I put the card in my card reader to see if it was indeed formatted and it appears not to be. I think my unit has problem writing to my card. I'm going to wait another week and when I get my boat in my driveway I'm going to see what I can do. |
Waccamaw Whaler |
posted 11-14-2009 01:34 PM ET (US)
Ed, all is not lost. I remember having the same problems getting started but I tried so many different things I can't remember what finally resolved it. I don't think HomePort is as user friendly as Mapsource but the more I experiment with it the more comfortable I am. I'm reluctant to give you advice because of my uncertainty yet but, for what it might be worth: There are 2 sections on the left side of your computer screen when you have the SD card in the reader: MY COLLECTION and MY DEVICES. In the DEVICES section there should be a folder named "UserData" or something similiar. The information in the "UserData" folder is what is on your SD card - I'm pretty sure of this. If I recall correctly, I think I opened both the "UserData" in HomePort and also the appropriate file in Mapsource. I then highlighted all of the waypoints, routes and tracks in the Mapsource file, using the shift key, and copied the information. Then I simply put the curser on any spot on the 'map' in the Homeport screen and pasted it. All the data was transferred at one time. As Tom suggested this may not be necessary but it worked for me. Now the data should be on the SD card and transferrable to the Garmin unit when you start it. I found that you can also open new folders in either MY COLLECTION or MY DEVICES. In MY COLLECTION I opened a 'Backup ******' file with a date and I simply slide my SD USERDATA into that file. As the data is being transferred there will be a thin green progress bar active directly under the file you are transferring the data to. I also opened several folders and named them whatever my longest tracks or routes are and pasted just that route or track in that folder for individual reference or transfer to the SD card at a future time if needed. I hope this helps and doesn't mislead you in anyway. Hopefully, Tom or someone more knowledgeable will chime in and be of more help. Ron |
bluewaterpirate |
posted 11-16-2009 02:18 PM ET (US)
Ed ..... What version of the 545 software are you running and what size SD card? Tom |
Liteamorn |
posted 11-16-2009 10:21 PM ET (US)
Tom I installed v 5.2 on 11/6/09 on my 545s I am using an 8 gb card as per your suggestion. I downloaded my maps to my card but none of my waypoints , routes or tracks were downloaded. I then was able to download many of my older waypoints and routes from my mapsource software on my computer downstairs. I wanted to try to get all of my newer waypoints to my 8gb card so I deleated all of the files, I went to the boat and formated my card (I am not sure it is formating though). When I try to download my maps again I get the "Cannot write to card" message with no reason as to why not. Ed |
Waccamaw Whaler |
posted 11-17-2009 02:27 PM ET (US)
Well, the 5.20 reinstall didn't correct my distortion problem so the unit is enroute to Garmin for repair. I'll let you know if it was a software problem just in case it's a potential problem for other users. Ron |
Liteamorn |
posted 11-20-2009 02:47 PM ET (US)
The latest update on my problems. Somehow I managed to lock my card when i put in in my little watch pocket in my jeans. I went back to the boat today (to windy to take her out)and got my map to upload to my 8 gb card. I went back into the manage card menu on my unit and tried to upload my data. The only thing that seemed amiss was that it stuck on sending routes. It said it sent my waypoints and my tracks and that the transfer was complete. I also got these messages in seconds. My card still had no waypoints on it until I uploaded all of the waypoints and routes I had on my old Mapsource software on another computer. |
Waccamaw Whaler |
posted 11-21-2009 10:09 PM ET (US)
Ed, are you sure you're transferring the data to the SD card. Just because it's on Homeport doesn't mean it's on the SD card. Open Homeport then reduce the size of the screen. Next, click on the Homeport 'USERDATA' file (or another you may have created) and simply slide that file over onto the SD card's icon. That should transfer all the data onto the SD card. If you still can't get it, I'd take your laptop, SD card and cell phone to the boat and call Garmin. I've called them numerous times and they are very patient & helpful. Don't give up Ron |
Liteamorn |
posted 11-23-2009 04:29 PM ET (US)
Ron When I read what is on my card via my card reader shows that I indeed loaded my maps but as far as my user data that file has 0 bytes in it. The boat will be in my driveway within a week or so and I will give it one more shot then. Ed |
Waccamaw Whaler |
posted 11-24-2009 07:03 PM ET (US)
WOW, I got my repair unit back from Garmin already and I had sent it to them via parcel post. They simply sent me a new unit. I just hope it works and I have no start-up software issues. Ed, it sounds to me like your are reading your internal drive when you are on the computer. I really suspect you haven't transferred he data to your SD card. You have to get the data from the computer to the Garmin unit as I described above. It's either that or you really do have problem which I doubt. |
Liteamorn |
posted 11-28-2009 10:28 PM ET (US)
Here is where the story gets REALLY wierd. I downloaded my maps (no other data would transfer from my unit)to my 8gb SD card. After going down to the boat and failing again at transfering my data I left the SD card in my pants and washed and dried them. When I found the card I left it out to completely dry. After checking to see if it could be read in my card reader (it could) I transfered my old waypoints from my Mapsource software and went back to the boat. When I first installed my card in my 545s the unit said the card was not formatted properly. I transfered the data to my gps and then I transfered the user data back to the card and this time it transfered everything, waypoints, routes and tracks. Everything works as it should now (shrug). Thanks Ron for taking time to help with this delemma. Next week I pull the boat. Ed |
Waccamaw Whaler |
posted 11-29-2009 12:52 PM ET (US)
I'm glad you got it working but that is really wierd. It's good to know if you get the card wet that it can be salvaged. When I returned my unit to Garmin for repair I told them to be careful they did not delete the BlueChart2 Vision data that was stored on the Garmin unit. I was concerned because I had inadvertantly overwritten the original card with waypoints etc. I had not seen Garmin's warning to avoid overwriting the BlueChart card. When I got the 'replacement' back, instead of my original unit, I called Garmin and they told me that as long as I had been able to read the data from the 8gb SD card I was using, and still had that SD card, the data would "ALL" still be on that SD card. They told me that the Garmin unit reads the data directly from the SD card. It does not "transfer" the data to the unit. I haven't had time to try the unit yet but to be honest I'm not convinced that I have not lost the BlueChart data. |
Chuck Tribolet |
posted 11-29-2009 02:07 PM ET (US)
BTW, those cards are relatively well sealed. A dive buddy recovered a camera from a lake a couple of days ago. The card was still readable, date of the last picture was April 2008.
