  Northstar 6000i Fishfinder
Author Topic:   Northstar 6000i Fishfinder
djtdmd posted 10-27-2009 10:47 PM ET (US)   Profile for djtdmd   Send Email to djtdmd
I have a 2006 255 Conquest with the factory installed option 6000i GPS, sounder and RADAR option. I have had [problems] with the sounder getting poor readings since I got the boat. I am now out of warranty, and didn't use the sounder a lot until this year, when I really got into fishing. My dealer has been great: they have swapped out my 6000i, swapped out my 491 Sounder module, and I put on a new Airman P66 transducer. My dealer swapped out this stuff so as to isolate the problem, and I still have [problems]. I lose bottom even at low speeds less than 6-nautical-miles-per-hour, my pixels become big cubes, my screen will go blank for [unclear] minutes at a time, and forget about a 20-nautical-miles-per-hour fishfinding cruise. I have twin Mercury Verado engines, and my tranducer is mounted where Boston Whaler recommends, on the port side, on the flat bevel right next to the port trim tab. The only thing I have not tried is to move the transducer more to the centerline, against Boston Whaler's recommendation. Any help from you guys would be great! Thanks, Dan
wood duck posted 10-28-2009 03:17 PM ET (US)     Profile for wood duck  Send Email to wood duck
Dan,I had the same problem with my 2009 235 Conquest and Garmin 4208. I finally had the P66 moved from port to starboard, as close to the centerline as possible ,away from the prop wash and turbulence from the trim tab, and also not in line with a thru-hull. Perhaps against BW's installation recomendations, however now the problem is solved. A local marine electronics retailer/installer made the recomendation to me. If you read the Airmar P66 instructions, it is very clear as where to mount the unit.
djtdmd posted 10-28-2009 03:48 PM ET (US)     Profile for djtdmd  Send Email to djtdmd
Thanks- was your transducer factory mounted? I assume it was mounted like mine just to the center of the port trim tab...I have twin verados, so I guess because they counter rotate, it doesn't matter if I keep it on the port side...I will move it to the centerline like you said- This really did solve the problem? Immediate difference? How about readings while running? Appreciate your help...Dan
wood duck posted 10-28-2009 04:41 PM ET (US)     Profile for wood duck  Send Email to wood duck
Dan,unit was dealer installed, according to BW installation guidelines. Yes, an immediate difference was recognized, while at rest and underway. I no longer lose bottom or get big "cubes" that fill the screen.
jollyrog305 posted 10-29-2009 04:53 PM ET (US)     Profile for jollyrog305
I was under the impression that the transom mounted transducer/paddle wheel relayed information to the SmartCraft system/display and that the Northstar received its information from the thru-hull transducer/echo sounder, GPS, Radar, etc. I will say that if I (initially) turn the system on in rather shallow water, I sometimes get really way off depth readings (1100’ vs. 3’) – but turning the system off then back on remedies the problem.
number9 posted 10-29-2009 05:42 PM ET (US)     Profile for number9  Send Email to number9
Looking at the whalerparts.com diagrams appears the transom mounted transducer/paddle wheel is mounted on the starboard side an the dual frequency transducer on the port side. They also show a thru hull for something.
djtdmd posted 10-31-2009 08:09 PM ET (US)     Profile for djtdmd  Send Email to djtdmd
Guys, I just had my whaler dealer remount the transom mounted airmar P66 today. They remounted it closer to the centerline, but not past the second strake. It is actually where airmar said to mount it. Whaler corporate did not agree, they insist they have it correct. We will see tomorrow when I take it out to the ocean. If it works, I will be happy to email anyone a photo of where they moved it to on my 255 Conquest w/ twin 150's.
bluewaterpirate posted 10-31-2009 09:43 PM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
I use a P66 transducer connected to my Furuno 620 FF. I've had three tranducers located in this same location since 2002 ..... all have worked as advertised.
http://cdn-2-service.phanfare.com/images/ 4892322_2160388_31001752_WebSmall_5/ Image-4892322-31001752-2-WebSmall_0_3bef548c1390254faea264dff2f5d2d4_1
Furuno 620
http://cdn-2-service.phanfare.com/images/ 4892322_2934439_51741608_WebSmall_3/ Image-4892322-51741608-2-WebSmall_0_cecae1827e12545de6ada881b9dcd3a9_1
http://cdn-2-service.phanfare.com/images/ 4892322_2934439_51643161_WebSmall_3/ Image-4892322-51643161-2-WebSmall_0_5b65537962a898a357f7f2a6c1481202_1
This is my Raymarine DS500 that was connected to an Airmar P58 TM
http://cdn-2-service.phanfare.com/images/4892322_2160388_31033019_Web_3/ Image-4892322-31033019-2-Web_0_4e9cb6f21f71b7cee137bf626e870012_1
http://cdn-2-service.phanfare.com/images/4892322_2160388_31032960_Web_3/ Image-4892322-31032960-2-Web_0_a56a83c6952a46bbca6622f10c65d9ac_1
http://cdn-2-service.phanfare.com/images/4892322_2160388_31032745_Web_3/ Image-4892322-31032745-2-Web_0_0052f0bbab2d46df1bd690ee70e67119_1
Some video of the 620 in action.
http://bluewaterpirate.phanfare.com/2160109_2325410#imageID=31024928
I've scratched my head more than a couple of times in regards to BW'rs factory installed TM ducers.
Over the last three years I've relocated five to more suitable locations. When it comes to twins with CR props I the tranducer between the motors just to the right of centerline drain. On single engine installs on the 1st strake just to the motor. You don't want the transducer housing below the strake bottom.
I've done one thru hull install on a 32' Outrage. It took me a couple of days to do it.
Tom
timing posted 11-03-2009 11:01 PM ET (US)     Profile for timing
I also use a P66 transducer connected to my Furuno 620 FF. The transducer installation pictured below performs well at all speeds with my Outrage 21.
http://i16.photobucket.com/albums/b2/1845JR/p66_aft.jpg
http://i16.photobucket.com/albums/b2/1845JR/p66_side.jpg
djtdmd posted 11-06-2009 09:24 PM ET (US)     Profile for djtdmd  Send Email to djtdmd
Hey guys--a quick update on the transducer placement on my 2006 255 Conquest with twin Mercury VERADO 150-HP engines. I can absolutely tell you all that the optimal placement for the transducer is on the starboard side, a few inches off the centerline, just to the right of the center drain. Whaler's factory install of the transducer was in a very poor if not useless position. I moved it below the first strake with better results, but lost bottom when up on plane. After moving it just off the centerline, the improvement was unbelievable. I can mark bottom over 30-MPH, well up on plane, and I could never do this before. It really irks me that Whaler is so wrong with their factory transducer placement with the electronics package on the which they insist is still correct, even though Airmar disagrees. This has caused me so much aggravation, time and fish, and they need to remedy this problem. The folks at Airmar (transducer) were great in helping me find optimal placement; it really is as they say that you should place these as close to centerline as possible. The reason we placed a few inches starboard of the centerline is that there is a water discharge fitting on the port side of the 255. Other than that, with counter rotating props, port or starboard should not matter. If you have one engine, you want to be on the starboard side a few inches off the centerline. I hope this post can help others deal with their Northstar Sounder issues. I always thought it was a Northstar problem, when it was really a transducer placement problem, which Whaler needs to correct. Thanks to all of you that helped me! Dan
