ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Yamaha Command Link Plus; YCOP Security System
Author | Topic: Yamaha Command Link Plus; YCOP Security System |
posted 11-25-2009 09:09 AM ET (US)
Yamaha has announced a new generation of Command Link controls for their outboard motors, the Command Link Plus. The display is a color LCD with five-inch screen. It can be configured by the user to show a variety of engine parameters. Command Link Plus includes a NMEA-2000 gateway that permits engine parameters to be displayed on other NMEA 2000-compatible devices, such as multi-function displays. Yamaha has also included an electronic anti-theft system. A special electronic key fob is needed to start the engines. |
posted 11-25-2009 09:34 AM ET (US)
The new Yamaha theft prevention system is called YCOP--Yamaha Customer Outboard Protection security system. The system is similar to security systems used in modern automobiles, where a radio transmitter key fob replaces the traditional mechanical ignition key. The YCOP system consists of two components: a small key fob transmitter (the "Remote Immobilizer"), and a receiver module. The receiver module is installed on the boat and connected to the Yamaha vessel network. It listens for signals from the key fob transmitter. When a signal to disable starting is received, the receiver module sends a command to the Yamaha engine (which is also connected to the vessel network), and starting is disabled. Even if the engine were hot-wired for starting, the engine speed is limited to 2,500-RPM, making a quick escape by the thief more difficult. More information available at: http://www.yamaha-motor.co.uk/products/information/ycop/ycop_fqa.jsp |
posted 11-27-2009 11:13 AM ET (US)
More information about the Yamaha Command Link, Command Link Plus, Digital Electronic Controls (DEC), and Customer Outboard Protection (YCOP) is available from SIM Yamaha at http://www.simyamaha.com/category_s/1971.htm where a PDF "Hot Sheet" can be downloaded. The direct link to the hot sheet is: http://www.simyamaha.com/v/vspfiles/images/ Command%20Link%20plus%20Hot%20Sheets.pdf |
