ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Color Coding of OMC Engine Wiring
Author | Topic: Color Coding of OMC Engine Wiring |
jetstream |
posted 12-20-2009 09:59 AM ET (US)
I need to know the color [of the wire] [on a] 1997 Johnson 115 SPL coming from the regulator [that connects to the] SIG [terminal] of an OMC tachometer gauge. The engine has no harness. Can I get the signal from one of the terminal blocks? Thank you |
posted 12-20-2009 10:12 AM ET (US)
The color of the insulation on the wire that typically feeds the tachometer signal is GRAY. Compare at: http://continuouswave.com/whaler/reference/wireColorCode.html#OMC Typically there is a connection point on the engine where the regulator-rectified assembly is located, and you should be able to access this circuit there. |
jetstream |
posted 12-23-2009 04:49 AM ET (US)
JimH Great help Thank you it works great. |
