ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Wiring Bilge Pump: Control of Pump With Carling Rocker Switch
Author | Topic: Wiring Bilge Pump: Control of Pump With Carling Rocker Switch |
bearborne |
posted 03-15-2010 02:02 PM ET (US)
I want to change to an automatic bilge pump from a manual bilge pump on a 1999 Boston Whaler Montauk 17. The existing two-way panel-mounted rocker switch is a Carling V1DA, and I would like to change to a 3-way to facilitate the automatic pump. Are these switches still available? Where could I locate one? Any other suggestions on the hook up of the auto bilge pump would be welcomed. Could I come directly off the battery to the auto-on wire on the pump and not even need a 3-way switch? Thanks, Barry |
posted 03-15-2010 04:06 PM ET (US)
In the REFERENCE section an article shows the typical wiring of a bilge or sump pump to permit ON-OFF-AUTO settings. See http://continuouswave.com/whaler/reference/bilgePump.html I don't have handy any reference for the Carling switches. |
number9 |
posted 03-15-2010 06:09 PM ET (US)
This might help you out getting the switch configuration you want. |
