  Best Trailer Lamps For Use in Saltwater
Author Topic:   Best Trailer Lamps For Use in Saltwater
Lil Ole Boat posted 06-02-2010 10:11 AM ET (US)   Profile for Lil Ole Boat   Send Email to Lil Ole Boat
I have never had good luck with trailer lamps. I am about to put a new set [of lamps] on my trailer and would like to buy the best [lamps] if it means that [the best lamps] are going to be less troublesome. What is the brand or style [of trailer lamps] of choice?
Tohsgib posted 06-02-2010 11:12 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
LED
tedious posted 06-02-2010 12:42 PM ET (US)     Profile for tedious  Send Email to tedious
Pipelights on PVC guide-ons. Nothing goes in the water.
Tim
Whaler_bob posted 06-02-2010 02:39 PM ET (US)     Profile for Whaler_bob  Send Email to Whaler_bob
In theory- the LED trailer lights "should" last longer cause the LED's and circuit board are potted (epoxied/sealed) as a one piece assembly. But, you will still have corrosion problems where there are connections between wires- like the pigtails from the LED light fixture connection to your trailer wiring harness. I just looked at my Jetski trailer this weekend and noticed the green lead from the LED assembly had separated from the barrel connector to the trailer harness.
Other nice thing with LED trailer lights is that each assembly has 10-20+ LED inside, even if one or two LED's die the array continues to function unlike conventional single bulb incandescent trailer lights.
Many LED's have a lifetime warranty too (check them out on Amazon).
sosmerc posted 06-02-2010 03:43 PM ET (US)     Profile for sosmerc  Send Email to sosmerc
I agree with tedious above!!
You can put a man on the moon......but don't expect a set of trailer lights to go much more than one season.....unless they are set up to never get submerged!!
contender posted 06-02-2010 03:47 PM ET (US)     Profile for contender  Send Email to contender
I hange my lights on the lifting rings on the outside of the hull, I run/lay the wire on the inside of the boat and plug them into the connection at your tow vechicle. I do not keep lights on/connected to my trailer. I have had the same lights for over 35 years, they never touch the water. Takes a little longer but I never have trouble with my lights. Lights do not last once they hit the water I do not care what you have...
Dave Sutton posted 06-02-2010 04:59 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
5 years on my LED's and they are as good as new.
Have launched about 40 times a year, all salt water. The lights are always submerged when I launch. I generally rinse with a hose after retrieval, but sometimes it's a few weeks between washes. Bottom line is that I don't baby them.
The trick of long life is to solder any connections, and then to use tool dip or any of the paint-on "liquid electrical tape" products. Use many thin layers of the paint-on stuff and it'll be waterproof forever. The lights are not the weak point, the wiring is. Use care in installation and it'll pay dividends.
Dave
Jefecinco posted 06-02-2010 05:36 PM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
LEDs. Peterson makes excellent lights with a superior warranty. Mine lasted several years and were going strong when the boat sold.
They have a web site. Google?
jimh posted 06-02-2010 11:48 PM ET (US)     Profile for jimh  Send Email to jimh
Moved to SMALL BOAT ELECTRICAL.
jimh posted 06-03-2010 09:36 AM ET (US)     Profile for jimh  Send Email to jimh
The DRY LAUNCH brand of trailer lighting devices has a good reputation. DRY LAUNCH lamps were the subject of a prior discussion at
http://continuouswave.com/ubb/Forum6/HTML/002454.html
David Livingstone posted 06-03-2010 09:59 AM ET (US)     Profile for David Livingstone  Send Email to David Livingstone
http://www.drylaunch.com/
I get three/four years out of these in saltwater. Grease the sockets during regular mantinance. I use heatshrink marine crimp connecters. Plus carry a spare when you back into something :) I can't use PVC pipes because of the way I retrieve my boat.
David
