  Solenoid for fuel enrichment valve
Author Topic:   Solenoid for fuel enrichment valve
LKD posted 07-28-2010 11:28 AM ET (US)   Profile for LKD   Send Email to LKD
I have a defective solenoid on the fuel enrichment valve, also called the Primer Starter Assembly in the parts manual, of a 2001 Yamaha 40-HP. To check it, I connected 12 volts to the contact that the hot wire is attached to, and the solenoid makes no response. Is there some other method I need to use to verify its condition? Thanks,
Keith
number9 posted 07-28-2010 04:28 PM ET (US)     Profile for number9  Send Email to number9
You are looking for movement after several minutes of having voltage applied. It operates similarly to a thermostat but heated by a small electrical coil.
