  Wiring Navigation Lamps for 13-foot Boat
Author Topic:   Wiring Navigation Lamps for 13-foot Boat
MidcoastMike posted 07-28-2010 12:31 PM ET (US)   Profile for MidcoastMike   Send Email to MidcoastMike
The wiring on my 13-foot boat finally [failed], so I am taking the plunge to rewire. I have a 3-position push pull switch, a 4-gang terminal block at the stern, a [combined sidelights lamp] at the bow and [a white all-round] light. Jimh--I have followed your reference: http://continuouswave.com/whaler/reference/navLightSwitch.html
And here is my proposed wiring diagram. Does it look right? What gauge wire do folks typical run? Thanks. --Mike
jimh posted 07-28-2010 03:43 PM ET (US)     Profile for jimh  Send Email to jimh
All boat wiring should be no less than 16-AWG, and larger if the circuit needs to carry more current or have a lower voltage drop than 16-AWG can provide.
MidcoastMike posted 07-28-2010 04:02 PM ET (US)     Profile for MidcoastMike  Send Email to MidcoastMike
Thanks Jim - I was thinking of using 14-AWG, so that's good. What do you think of the diagram - will that work correctly?
jimh posted 07-28-2010 08:03 PM ET (US)     Profile for jimh  Send Email to jimh
For a 13-foot boat, I would use a SPST switch that connects the battery positive to the lamps. How many times do you plan to be at anchor in a non-anchorage area at night with your 13-footer? That's the only time you would need to show different navigation lights. Otherwise they're either on or off.
jimh posted 07-28-2010 08:24 PM ET (US)     Profile for jimh  Send Email to jimh
Your wiring as diagramed should work. You might want a fuse in the lead from the battery to protect the circuit.
Tom Hemphill posted 07-28-2010 09:31 PM ET (US)     Profile for Tom Hemphill
Those who fish or SCUBA dive for lobsters at night may fall into that category. In the latter case, the all-around white light is very helpful to locate your boat when you surface.
jimh posted 07-29-2010 12:02 AM ET (US)     Profile for jimh  Send Email to jimh
If you are diving at night, I would think you would want to show more lights than just a white all-round. Diving activity is usually indicated with a signal for RESTRICTED ABILITY TO MANEUVER, which is RED over WHITE over RED, spaced at least 1-meter apart, the lowest light 2-meters above the gunwale.
MidcoastMike posted 08-02-2010 03:10 PM ET (US)     Profile for MidcoastMike  Send Email to MidcoastMike
Here are the pics of the finalized wiring diagram and the completed install. This was a fun project!
http://www.whalercentral.com/infusions/personal_page/ppages. php?ppage_id=10853
