posted 10-10-2010 10:06 PM ET (US)
The components inside the typical SONAR transducer are usually copper wire and a piezo-electric element often made from ceramic material. The thermo-plastic housing of the transducer will typically have a lower melting point than either copper or ceramic materials. If the temperature of the transducer was not hot enough to deform the thermo-plastic, it seems reasonable to think the ceramic and copper components were not likely damaged. The lead-tin alloy used to solder connections probably also has a higher melting temperature than the thermo-plastic housing, and it would be unlikely any solder connections were damaged.The position of the transducer relative to the water flow, any aeration in the water flow, or any upstream obstructions in the hull all affect performance. Try moving the transducer up or down slightly from its current location to see if the performance is improved. Often a small adjustment can make a significant change in performance. |
