ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Visibility of Navigation Lamp on 1965 Boston Whaler 13-footer
Author | Topic: Visibility of Navigation Lamp on 1965 Boston Whaler 13-footer |
Boston Whaler1965 |
posted 10-28-2010 09:47 PM ET (US)
[What] distance in nautical miles can the factory [combined sidelight lamp] on a 1965 Boston Whaler 15-footer be seen? The reason I am asking is because I have to replace my whole lamp assembly and chock. I found the one Specialty Marine sells-- which is nice--but [I] wondered if [I] should install it with a little larger light that looks very similar but can be seen for a known two nautical miles. The one from [S]pecialty [M]arine does not come with a marine wire tinned pigtail. I called them and they could only tell me that it is OEM-specification-compliant, but they do not have the slightest idea how far it can be seen. It is a very small light, and I am only assuming it can be seen only for one mile. I did find a nice stainless replacement that looks almost the same but can be seen for two nautical miles and a hell of alot cheaper. I would still have to buy the whole chock assembly with the lamp, though, because they seperate the lamp from the chock and sell it seperately. But you cannot buy a chock without the lamp. Mine is badly discolored and pitted. While we are on the subject - Does anyone know the regulation on the necessary height [for the white all-round light] for the exact same boat? Thank you in advance guys for any help - Paul. |
posted 10-28-2010 10:20 PM ET (US)
See: http://continuouswave.com/whaler/reference/FAQ/#Q11 The visibility of navigation lights are given in http://www.navcen.uscg.gov/index.php?pageName=Rule22 The minimum visibility of the sidelight of a vessel less than 12-meters in length is one mile. The year the boat was manufactured does not affect the rule. Only the length of the boat affects the required visibility. |
Boston Whaler1965 |
posted 10-28-2010 10:29 PM ET (US)
Thank You Jim - I have learned a lot on this site and I do appreciate the help you have given me on restoring this boat. - Thank You again ...Paul |
There is a required vertical separation between the sidelight and the white all-round light of one meter. Most small boats are rigged with a white all-round light and do not have a masthead light and stern light. |
