  Nav Light ON with the switch OFF
Author Topic:   Nav Light ON with the switch OFF
padrefigure posted 11-08-2010 02:01 PM ET (US)   Profile for padrefigure   Send Email to padrefigure
I was headed to the airport very early one morning last week and happened to glance at my Outrage 22 resting on its trailer in the back yard. The red running light appeared to be on. At first, I thought it might be reflecting light from my truck, but I headed over to take a closer look. Indeed, the red light was burning. So I climbed in the boat to turn the switch off. But the switch was already off, so I turned it on. The light got brighter, but when I turned it back off, the red lamp continued to glow. When I turned on the switch, the green light came on, but was noticeably dimmer. All of this was after a pretty big thundershower, so everything was wet. By this time, I was out of time, so I dashed for the airport. My wife turned the battery switch off and took care of the immediate problem, but my question now is what caused the red light to come on in the first place? I have a very simple wiring set-up: Batteries to 1-2-Both-off Perko switch, Perko switch to fuse block, fuse block to bank of six marine switches, switches out to different loads. (Red and Green running lights wired together, All-around white light, under gunnel lighting, bait well, (2) spares). My running lights are Attwood LED units that have performed flawlessly to this point. Where do you think I am getting enough current to power an LED light with the switch "off"?
Bulldog posted 11-08-2010 11:59 PM ET (US)     Profile for Bulldog  Send Email to Bulldog
Check the switch, could have a wet dirty situation allowing some power across the open switch, easy way to check is switch the wires to one of the other switches for a test. I assum ethe switches are protected from water and that the only things on the nav. light switch are the two nav. lights.....jack
jimh posted 11-09-2010 07:38 AM ET (US)     Profile for jimh  Send Email to jimh
Is the switch that controls the navigation lamps wired in the positive lead?
jimh posted 11-09-2010 08:16 AM ET (US)     Profile for jimh  Send Email to jimh
Also, the mystery here is why only one of the lamps is illuminated. I assume that the two sidelight lamps are wired to the same switch pole. It is hard to construct a situation with the switch where it only provides power to one of the connected lamps.
Jerry Townsend posted 11-09-2010 10:35 PM ET (US)     Profile for Jerry Townsend  Send Email to Jerry Townsend
You obviously have a high resistance short (water, crud, et al.) around the switch - to cause the light to be lit. The hooker is the dimmness of the green nav light when you flip the switch - which says that there is further resistance - to ground - in that circuit as well. Consider giving your existing switch the "merry ride". --- Jerry Townsend
padrefigure posted 11-10-2010 07:55 PM ET (US)     Profile for padrefigure  Send Email to padrefigure
yes, the switch interrupts the positive lead. All neutral (black) leads terminate in a ground bus. This weekend I plan on disassembling the switch bank, thoroughly cleaning, coating with corrosion X and re-installing. I will also check the terminations on the the green nav ligth--perhaps there is some oxidation built up creating resistance. I will let you know what I find.
Chuck Tribolet posted 11-15-2010 08:52 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Red light on, green light off can be explained by LEDs. The
two side lamps have LEDs with a different forward voltage drop.
Let's say the red is 8V and the green is 10V. That means the
red will come on at 8V and the green at 10V. AND there's
a high resistance short at the switch. The short will flow
enough current to turn on the red, which will pull the voltage
down to 8V. 8V is less than 10V, so the green doesn't turn on.
At full voltage, the lights have a current limiter chip that
pulse width modulates the power. But at low voltages, that
limiter chip just turns on.
LEDs can cause crazy effects. I replaced all the bulbs in
the brake lights on my
Nissan Pathfinder with LEDs. After that, every time I
signaled a turn, the cruise control would disengage. What
was happening was that there was a minute amount of leakage
current from the turn signal circuit to the brake circuit.
With incandescents, the small current wasn't enough to raise
the voltage. But with LEDs, the voltage across the hot side
of the brake lights was raised to the forward voltage of the
LEDs, and that got back to the cruise control circuit which
thought I hit the brakes and disengaged. The solution was
to replace one of the 6-8 LEDs in the CHMSL with an
incandescent.
jimh posted 11-15-2010 10:13 PM ET (US)     Profile for jimh  Send Email to jimh
I think Chuck's suggestion of different forward voltage drop in LED lamps of different color is only plausible if there are a different number of diodes in the internal wiring of the lamp. I don't recall that different color LED's had different voltage drops for individual diodes.
Chuck Tribolet posted 11-16-2010 12:15 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
I pulled up the data sheets for a random LED (Lumileds Rebel).
Green has a forward voltage of 2.55V, red is 2.31V.
jimh posted 11-16-2010 05:27 PM ET (US)     Profile for jimh  Send Email to jimh
Well, as the old saying goes, you learn something every day. I did not realize that there was such a range of forward voltage drop among the various types of colored LED's. There is a good Wikipedia article on this topic:
http://en.wikipedia.org/wiki/ Light-emitting_diode#Efficiency_and_operational_parameters
However, what has not been demonstrated is that in the boat in question the lamps use colored LEDs. The lamps could use a standard white-light LED and then use a colored lens to create the colored light. It may very well be that this is indeed the technique, because the light emitted by a navigation lamp has to conform to a certain color spectrum to meet the technical requirements of a proper navigation lamp. The red light from a red LED or the green light from a green LED might not fall into the permitted color spectrum.
jimh posted 11-16-2010 05:28 PM ET (US)     Profile for jimh  Send Email to jimh
Oops--here it the link I meant to include above:
http://en.wikipedia.org/wiki/Light-emitting_diode#Colors_and_materials
jimh posted 11-16-2010 05:34 PM ET (US)     Profile for jimh  Send Email to jimh
The chromaticity of navigation lamps is specified in:
§ 84.13 Color specification of lights
http://www.navcen.uscg.gov/index.php?pageName=33CFR84#13
but the format of the specification is not in wavelength of light but rather in units defined by the International Commission on Illumination (CIE). According the Wikipedia article the wavelength of emitted light from green and red is
RED = 610 to 760 nm
GREEN = 500 to 570
If we have any physicists reading who can convert wavelength of light to the International Commission on Illumination (CIE)specification, we would appreciate a demonstration in this case. Thanks in advance.
jimh posted 11-16-2010 05:44 PM ET (US)     Profile for jimh  Send Email to jimh
Well, here is a start. I found this chart:
http://www.nichia.co.jp/en/product/led_color.html
If we look at the bounding box for "G" or green LEDs, it looks like the boundaries are approximately
Y = 0.64 to 0.75
X = 0.13 to 0.22
Chuck Tribolet posted 11-16-2010 05:58 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
White LEDs are more expensive than colored LEDs. It would
be dumb to use a more expensive LED, AND have to use more
LEDs because the lens attenuates the other colors.
jimh posted 11-16-2010 10:21 PM ET (US)     Profile for jimh  Send Email to jimh
Chuck--Your reasoning is reasonable, but it does not demonstrate conclusively that the lamps in question have specific colored LEDs in them.
Now I was giving some more though to the "white" light from a white LED. A white LED makes is light by a combination of light from red, blue, and green LEDs mixed together. Even if you put a color filter in the lamp to change the light to the proper color or chromaticity, if the "white" LED did not emit any light in that spectrum you might not get much light output.
We need padre' to disassemble the lamps on his boat to see if they LEDs inside them are colored LEDs or white LEDs. That is about the only way to resolve the question.
Chuck Tribolet posted 11-17-2010 09:24 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
That's NOT how white LEDs work. The actual LED is a deep blue
(close to UV) LED that excites a white phosphor.
And even if they worked the way you say, you would still be
loosing 2/3 or so of the photons to the colored filter.
jimh posted 11-17-2010 02:06 PM ET (US)     Profile for jimh  Send Email to jimh
Chuck--I haven't made a study of modern LED lamps, but I rely on Wikipedia, which says:
"There are two primary ways of producing high intensity white-light using LEDs. One is to use individual LEDs that emit three primary colors[52]—red, green, and blue—and then mix all the colors to form white light."
If you have expert knowledge about how LEDs make white light, you perhaps might want to become the editor of the Wikipedia article and emend it so it stops passing off this bad advice to people who read it.
jimh posted 11-17-2010 02:25 PM ET (US)     Profile for jimh  Send Email to jimh
To get back to my question:
Do the typical "red" and "green" LED lamps emit light which satisfies the technical requirements for red and green sidelights?
Chuck Tribolet posted 11-17-2010 03:50 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
From the same Wikipedia article:
"However, the phosphor method is still the most popular method for making high intensity white LEDs. The design and production of a light source or light fixture using a monochrome emitter with phosphor conversion is simpler and cheaper than a complex RGB system, and the majority of high intensity white LEDs presently on the market are manufactured using phosphor light conversion."
http://en.wikipedia.org/wiki/Light-emitting_diode#White_light
jimh posted 11-18-2010 03:09 PM ET (US)     Profile for jimh  Send Email to jimh
Navigation lamps are a special case of "colored light." I don't believe that manufacture of navigation lamps using LED light sources would necessarily have to be bound by the market trend toward a particular technique. It very well could be that 99-percent of LED lighting used a certain type of LED and technique, but in a situation where colored light of a specific chromaticity was required, an alternative technique was used to create it.
On a marginally related note, the interior of my car has indirect lighting for ambiance that can be selected from a variety of colors. I suspect that the light sources are red, blue, and green (and perhaps more) LED's which are switched on in various combinations to create the different colors, including white. That is a case of white light being made with LEDs of various colors, and in rather high volume of production.
padrefigure posted 11-18-2010 07:02 PM ET (US)     Profile for padrefigure  Send Email to padrefigure
The LED's are indeed red and green, not white with a color filter. To Chuck's point, LED's are most efficient as a monchromatic source and navigation lamps (and traffic signals, exit signs, etc.) are monchromatic applications, so there is no good reason to take bluish light, transform it with phosphor to full spectrum and then filter out 90% of the light which is now the wrong color.
I cleaned everything up and the problem disappeared, but I am not sure that the problem was not already gone due to the fact that we have not had rain for several weeks.
Anyway, thanks for the advice and lively discussion.
