Topic: Lowrance HDS-5: Custom Screen Set Up; Powering Away From Boat
SJH |
posted 03-08-2011 04:13 PM ET (US)
I just purchased a HDS-5. Reading the owners manual, I didn't see an option in their data overlay section, to show current speed. I saw the time option. Is there a show speed option, lister under the "other"?To power up unit at home, is the Cigarett power cable part #99-10 the best option? No, I haven't had it out of the box yet, and there's still a foot of snow on the ground in MA. So it will be another 6 or 8 weeks before I get the boat in the water. My goal is to use the simulation mode, to learn its functionality. Stan
posted 03-08-2011 08:58 PM ET (US)
Stan--I don't think a plug designed to fit into a cigar lighter socket in a vehicle would be a good choice for powering at home, unless you happen to have a 12-Volt power supply with a cigar lighter power socket. I bought an extra power cord for my HDS-8 so that I could run it on my bench from the bench 12-Volt power supply. |
RobP
posted 03-09-2011 06:38 AM ET (US)
Stan: Just tear the box open. You will find the power cable has a + and - cables. Just get a couple of alligator clips and a small 12v battery. That way you can power it. I have some pictures some where the might but I have to head out to work. Will try to post up tonight or tomorrow morning. |
SJH
posted 03-09-2011 08:35 AM ET (US)
Thats a good idea about using alligator clips. I have a couple. I'll have to give it a try.Jim, I already have an adaptor for a cigarette plug, to a 12 volt transformer, that I use when I play with my Garmin GPS. That should work. Thanks for the ideas. Stan |
SJUAE
posted 03-09-2011 02:49 PM ET (US)
StanBefore you rush out and power it up make sure you include the inline fuse in your set-up just to be on the safe side with you new toy. If you want you could even try it in the car (with the heater on :) ) Don't forget to download the latest updates from the Lowrance website Regards Steve |
RobP
posted 03-10-2011 07:07 AM ET (US)
Stan: If you have not opened up the box here is a picture of the back of a HDS8 but the 5 is the same along with the power/NMEA 0183 cable and the sonar cable.LINK The red and black cable are the power, the yellow is a wake up cable for accessories. The other Orange Yellow Green Blue and bare wire are for the NMEA 0183 connection to a GPS. Like Steve suggested an in-line fuse is a good idea especially if hooked up to a bench top transformer or to a 12v outlet in your car. |
SJH
posted 03-10-2011 08:33 AM ET (US)
I connected power using the aligator clips. It worked great. Now I'll add the fuse. GOOD IDEA !Thanks stan |
SJUAE
posted 03-10-2011 02:41 PM ET (US)
StanJust add a Whaler and water and your good to go :) Enjoy Regards Steve |
andygere
posted 03-11-2011 04:36 PM ET (US)
Many 12-volt jump starter packs (really just a small 12 V battery with integral jumper cables) also have a 12 V cigarette lighter outlet. These make a convenient temporary power supply for marine instruments. Splice some alligator clips to the leads on a cigarette lighter plug from the auto parts store. |
