posted 06-14-2011 04:22 PM ET (US)
After 6 years, I had to replace both the 30A (main) and 5A (bilge) circuit breakers mounted in the little black box on the floor of the inside of the console. Erratic operation- false trips, can't reset, etc.Since I tend to disassemble failed components out of curiosity, I was surprised to see that these breakers (made by "ETA") weren't air/watertight - they popped open easily and indeed the components inside were corroded.
Seems like poor design for a marine component that's installed in an enclosed area easily subjected to dampness.
The front panel breakers are the same brand, but they are up higher and partially exposed to the outside (warmer, drier) air. But now I'm thinking I ought to replace those before they go too.
Is there a more robust version of these simple push botton breakers available, and has anyone else run into this problem?
