posted 03-29-2013 01:35 PM ET (US)
The classic Outrage 25 hulls have a large bow storage locker. It is 4-5 feet long with a flat bottom about 2 feet wide. At the stern-most portion, on each side, is a "shelf" about 1 ft wide and 2 ft long, about 1 ft above the floor of the locker. I think on the Revenge 25 boats this space is used for part of the cabin, but on the Outrage it is essentially wasted space. The prior owner stored lifejackets there.My boat, with twin Optimax 150s on jackplates, is certainly not bow heavy and would benefit from more weight up front. As part of my electrical re-fit, I plan to at least move the batteries from the stern to the console - I don't use the console for storage much anyway. However, that wasted space at the stern of the bow locker is tempting.
Whaler built the boat with a covered connection from the bow locker into the starboard rigging tunnel, so wire access from this location to the console appears readily available. This location is just slightly ahead of the console on a bow-to-stern basis and about 1' below the floor.
I have AGM batteries, so little venting would occur from them. My only real caution is the potential venting of the area, and potential gas fumes there should a leak ever occur. As is, that location is separated from the rearward gas tank cavities, and it would not be hard to caulk the existing access hole (which is currently covered) after passing wires through it. I don't think the ventilation there is a real concern - overall the area is similarly ventilated to a console.
I am not worried about the potentially tougher ride of the batteries there - AGMs are plenty tough in my perspective.
I can't see this spot ever being actively flooded over the tops of batteries. The bow storage locker has a hatch, and the "shelf" is at least a foot off that floor, not counting the height of a battery box.
I'm curious if you may have ever seen this area used for batteries before? Or what other uses have you seen for this area? Considering both sides, it is quite a bit of space that is currently unused.
Thanks for your input.
