  Rocker switches on electrical console
Author Topic:   Rocker switches on electrical console
Jeff Cardillo posted 06-24-2013 11:03 AM ET (US)   Profile for Jeff Cardillo
This weekend, I noticed my rocker switches for the electrical components were soft, with the black portion breaking down and getting all over my hand, like tar. The center has an activation light.
Is this common for a 2002 Dauntless 16 and only a dealer item?
Thank you for your help.
jimh posted 06-24-2013 01:50 PM ET (US)     Profile for jimh  Send Email to jimh
Breakdown of thermoplastic in high temperature and after UV exposure is fairly common.
Boston Whaler does not make their own electrical components like switches. I am sure you can find them at many resellers. It is a question of how much searching you want to do and how skilled you are in ordering the correct replacement. Part numbers for electrical switches are some of the most complicated part numbers known to man due to the many variations and options that are possible in their design.
I recommend removing the OEM switch and carefully inspecting it visually for a mark of a vendor and part number. Armed with that information you can likely order it from many sources.
wmdlambert posted 06-24-2013 02:57 PM ET (US)     Profile for wmdlambert  Send Email to wmdlambert
Jeff,
You may be able to simply replace the plastic rocker portion of the switch, which your hand comes into contact with. The cover simply snaps on and off. Seachoice Products, Pompano Beach, Florida makes several variations of the rocker switches.
jimh posted 06-24-2013 04:05 PM ET (US)     Profile for jimh  Send Email to jimh
Don't overlook Boston Whaler customer service as a source of information. Boston Whaler customer service may be able to tell you precisely who made the switch and exactly what part number is needed for replacement.
jimh posted 06-24-2013 04:13 PM ET (US)     Profile for jimh  Send Email to jimh
Browse this catalogue to get some ideas:
http://www.carlingtech.com/sites/default/files/documents/ Marine_Catalog_041213.pdf
Jeff Cardillo posted 06-27-2013 08:33 AM ET (US)     Profile for Jeff Cardillo
Thank you for the wonderful suggestions.
