posted 11-07-2000 11:10 PM ET (US)
Mike,
I hate to break the bad news to you, but a BW will sink if the conditions are right.If the core becomes wet and the water freezes in the core, the foam breaks down and becomes mushy(This usually takes a few winters with freezing weather). When the foam core becomes mushy the inner and outer hulls flex and accelerates the foam breakdown. This allows more free space in the core area to fill with more water(if the water entrance point was not repaired). As this process progresses along the positive bouyancy of the hull decreases.
I have seen this in several BWs, but most of them were severely used and abused. Maintenance was non-existant.
My question about a Florida boat with a saturated core is how did the water enter the core and has this boat always been down south?
If you are thinking about purchasing a BW with a saturated core, make sure your fiberglassing skills and your patience are high.
