posted 02-24-2001 08:43 PM ET (US)
Regarding the Bimini Top on the 13-Sport(new):I saw a Bimini top fitted to a 13-Sport(new) at a boat show. The hinge point of the top frame was mounted to the side rails of the boat. The top was stabilized with web straps fore and aft. At first glance this looks like a good set up because you don't have to drill any holes in the boat for the hinges; they slip around the railing of the side rails and clamp on.
In the up position it looked fine. I unhooked the forward straps and folded the top down into the stern. (The frame hinges were arranged such that this was the direction it wanted to fold.)
The result was a completely unstable mess. The rails of the frame folded down and landed on top of the side rails, leaving the folded top suspended about 6-8 inches above the gunwales of the boat. The frame wanted to slide to one side or the other of the boat's side rails, but this would require the whole frame to bend out of alignment.
The saleswoman came over, quite upset with me, and wanted to know what I was doing. I told her I was trying to stow the top. I asked her how it stowed, as the way I folded it was clearly totally unstable and not an acceptable method for stowing the top.
She had no answer for me--I don't think she understood that one might want to stow the top without removing it from the boat entirely. She put the top back up and made it clear to me that I was not supposed to fiddle with it anymore.
On the 13-Sport (classic) the side rails are mounted inside the gunwales, but on the 13-Sport (new) they are mounted on the the gunwales. So there is no place on the gunwales that a hinge could be mounted.
I would like to hear of anyone who has figured out a better method of mounting the bimini top.
I don't know if the installation I saw was the "factory" mounting or the if it was just a top the dealer had added.
--jimh
