posted 03-06-2001 04:29 PM ET (US)
Hello Allen,The 40hp that I use on an inflatable 12' dinghy is a Yamaha. I have excellent experience with it so far. It was in heavy use during all the summer season and performed flawlesly. The brand you choose mainly needs to have support either "just in case" or, I assume, later when running hours accumulate. Yamaha are considered very good in this range of outboards. Mine is also equipped with the tilting mechanism that also performed perfectly so far.
The Doel Fins do require holes to be drilled but I see no problem as you can always fill them if you choose.
The fins do mean that you will have a larger turning diameter and may sometimes feel "loose" on directional stability but to a minor degree. In any case, they provide such better planning and fuel consumption that the disadvantages are dwarfed.
All the best,
Yoav
