Topic: 40hp 4 stroke Mercury hole shot resolved!
awares |
posted 03-21-2001 10:25 PM ET (US)
I am one happy 2001 13' Sport owner this evening. As some of you know I have bought a new sport with the 40hp 4 stroke engine and was very unhappy with the hole shot performance.Everything else about the motor I love. Easy to start, no smell, 10.5 miles per gallon, no oil to be added, and no problem with the weight. No water over the back of the transom and sits fine in a static position. Testing the boat with the standard stock prop that came with the boat I achieved the following results. (15" aluminum pitch prop) 5800 rpm's, 37-38 mph, for ever getting on plane. Tested this evening on Lake Travis with a four blade stainless built by Power Tech out of Shreveport, LA. Prop Model: M70 SCB4R 12 Satin (4 blade-12 pitch) Results: Great hole shot! "Immediately on top of water. Maximum rpm's of 5900 and unbelieveable top end speed of 45-46mph. This motor performed so differently I first thought I had a standard 2 cycle motor. I can now move on to rigging the interior because from a motor performance I am stopping. Pulling a skier will not be an issue from this point forward. I credit this to Mike and J.T. Nettle at Nettle's Prop Shop in Austin, Texas for having the knowledge to hit it right on the very first try. It is hard to find dealers and people that know what to do anymore. Also Power Tech's web site is www.ptprop.com. Also feel free to call the Nettle's in Austin Texas if you have a question. Phone number is (512) 837-7707. I am only a consumer that demands top reliable performance, I am not a salesman.
whalernut
posted 03-22-2001 07:59 PM ET (US)
Those Dudes did Magic to you`re motor! I can`t believe the difference in performance you are telling us! That 4 blade prop is like a miracle! Congratulations, and keep us posted on later performance results with full weight, skiiers,etc. Regards-Jack Graner. |
Bill Davis
posted 03-22-2001 09:12 PM ET (US)
Awares: Keep us posted on all further developments, and by that I mean on your progress and thoughts on interior. Maybe ought to use your "outfitting has begun" subject line. I'll stir that a bit right now.thanks for the education--I wonder if I would greatly benefit from such a prop. I have a 30merc 2 stroke on my 2000 sport 13' and the prop is pretty nicked up.... bill |
Tom W Clark
posted 03-22-2001 09:48 PM ET (US)
awares,Are we to understand you correctly: you now have a 13' boat that is capable of going 45 mph? And the boat is within its maximum hp rating? When I had a 13' I remember it went about 35 mph, and being that close to the water it seemed pretty damn fast! Did you order the nitrous oxide option on your motor?! |
awares
posted 03-22-2001 10:39 PM ET (US)
The top end speed was beyond my wildest imagination. I own a 1968 13' Whaler that I keep trying to compare this boat against. I have realized that I can not do that any longer because they are similiar in some areas, but overall performance is so much different.As I stated in an earlier post I thought I would install a new 40hp 2 cycle engine on my old Whaler. If I can scrape up the difference between the two when the hull and interior is completed I will now buy the 4 stroke. I just need to think through the weight addition between the two and the addition of the set back plate that will accomandate a long shaft motor. If someone had told me I would be able to go faster than 40mph in this boat I would have taken that bet. Well it is true and I still can not believe that I achieved 45mph. Whaler needs to go back and do their own validation tests on several prop types. I personally feel that they could sell more of these boats if they would maximize the performance and share it with the general public. I know that bad news travels faster and further than good news. I feel sorry for the guys that are not as persistent as we are with our Whalers. |
2001 13 Sport Owner
posted 03-23-2001 12:08 PM ET (US)
Awares! Sounds like the guys at Nettles really solved your hole shot performance problem. It is unbelieveable how the right prop can improve performance. As you know, my boat has the 25HP 4-Stroke. I am trying to get my dealer to trade out my engine for the 40HP 4-Stroke. His most recent recommendation was to trade my boat in on a 40HP 2-Stroke. The dollar difference would be minimal. However, the reason I went with 25HP 4-Stroke in first place was because I like the 4-Stroke engines due to the lack of smoke and quietness. I also believe the 4-Strokes are probably better when it comes to maintenance. I had also considered buying a used 15 Dauntless, but have decieded against that as long as I can improve my hole shot perfromance and top end speed. I really like the way my 13 Sport handles and it is a perfect first boat for learning the bays along the Texas Gulf Coast. When I am ready to upgrade to a bigger boat, I will go with something around 17 to 20 feet long. I will let you know what I decide to do. Thanks for sharing your results with us. |
whalernut
posted 03-23-2001 05:04 PM ET (US)
Maybee the trick to the 4-stroke magic is to swing a 4 blade prop! It sure worked for Awares. Because of the (4 strokes) needed to fire the shot, maybee the 4 blade prop evens that facts of a 4-stroker out? Someday, I would love a 4-stroker for my old `16, and will have to experiment myself. Regards-Jack Graner. |
Hank
posted 03-23-2001 09:46 PM ET (US)
Awares I'm curious. What's the gear ratio on that 4-Stroke ? That increase in speed with a prop of lesser pitch seems incredible. That aluminum prop must have been exceptionally inefficient. My two cycle 90 HP Evinrude has a gear ratio of 2:1.( That is Tach RPM to Prop RPM.) I run my Montauk with a 19 pitch 3 bladed stainless prop. I max out at about 40 MPH at 5200 RPM. This calculates out to about 87% efficiency at WOT. Hank |
Lil Whaler Lover
posted 03-23-2001 11:01 PM ET (US)
I have been waiting to see if someone would question the reported performance on awares 13 Sport with a 40 four stroke. It has not happened so I have to ask the following question. How much cup and or rake is in this prop? By my calculation awares is achieving 134% of theoretical speed with this set up with a 12" pitch prop.The numbers reported on the 15" aluminum work out to a very respectable 9% slip and make sense on an efficient hull. It would take an 18" pitch at 90% efficiency to reach 45 mph. Please help me understand the dynamics of how these reported performance levels are reached. Thanks, Dave |
awares
posted 03-24-2001 12:06 AM ET (US)
Lil Whaler Lover, As I stated in a earlier post when I started to rig my new Whaler I was disappointed in the hole shot. I am not a prop expert by no means and that is why I went to the very best prop people I know in Texas. I am very fortunate that they are also in Austin Texas.I am a firm believer that a motor is only as good as its propeller. I am not a engineer, but I am a quality and process manufacturing manager. I expect the finest performance from anything we manufacture and anything I buy. Its true I do drive some of my counter parts crazy, but I am always looking for a continuous improvement. I do not understand the laws of performance and how you calculate motor to prop ratio. I do understand that I have never gone beyond 33mph in a 13' Whaler until I bought this one. I a sure you that this new rig trimmed out and running 5900rpm on a Power Tech propeller M70 SCBB4R 12 Satin 4 blade stainless on 4 stroke Mercury motor punched 45mph before I pulled it back. Please contact Power Tech at www.ptprop.com or Nettles Prop Shop here in Austin and ask them the specific questions on how this can be. Nettles phone number is (512) 837-7707. Also I do not know the specifics about what you need to know about the motor to help you calculate the expected result. That information should be available on the Mercury site. As I stated I did not believe it myself. I would love for Whaler and others to perform tests on this prop and others and share the results with all of us. Why is it that the consumer has to figure out a manufactures performance formula. I also love my 1968 13' Whaler and would not trade it for anything. Each boat has its own identity and feel. If you are ever in Austin bring your life jacket and will let you experience it up close and personal. It is a sensation better than anything you will get at any theme park. Please let me know how the final calculation works out. I also invite any other Whaler folks if you are ever here in Austin please contact me because I would love talking to you about Whaler's and let you drive mine. Contact me at awares@galaxymicrosystems.com Allen Wares |
whalernut
posted 03-24-2001 06:36 AM ET (US)
Allen, that is a most generous offer that you extend you`re hand to other Whalerers! I feel the need to do the same, so if anyone wants to go Whalering with me up on Lake Erie this year, give me a holler at whalernut@libcom.com and we can chew the fat and I will give you my phone # there. I don`t know about you fellows, but I feel as much pride when somebody is riding and/or driving my Whaler in general! My boat is located in Conneaut, OH. 45 min. from Cleveland, OH.- 30 min. from Erie, PA. and I live in Pittburgh, PA. 2 and one-half hours from there, but go to Lake Erie almost every weekend in the summer, and usually take a weeks vacation in June/July. Please let me know, if you want to go fishing(Yeeha) all the better! Regards-Jack Graner. P.S. The Beer is cold! |
Clark Roberts
posted 03-24-2001 07:20 AM ET (US)
Allan, I ,like Dave, am trying to figure this one out... not doubting the results, mind you, just trying to put it together. Your engine has a 2:1 lower unit and at an rpm of 6000 would be spinning the prop at 3000rpm. If prop was 100% efficient (and if it acted as a screw at those rpms - which it doesn't) it would travel 3000 X 12" each minute.. that's 3000 feet per minute or 180000 feet per hour which is 34 miles per hour. Note that a prop doesn't act as a simple screw except at very low displacement speeds, but rather, acts as a non-encased axial flow pump which gathers water from the sides (not the front) and accellerates it as a water jet and it's this action/reaction against the jet that propells boat forward! you can see this jet surface in mid wake behind your boat. A boat cannot exceed the speed of this water jet! Don't want to bore anyone with this stuff but am trying to figure out how these speeds were achived... Allan, how did you measure your speed...with GPS, pitot speedo....paddle wheel speedo..??? Example of other 45mph boats are: Dennis Scott, Sneads Fla has a 17' with 75 Merc (2.3:1 lower unit ratio), 21" pitch ss (stilletto I think) at 5350 rpm, engine up two notches and doel-fin, measured by GPS, calculated 100% efficiency speed is 53mph; my 21 revenge with 135 Merc opti (2:1 lower unit ratio) , 19" pitch Quicksilver Vengence ss prop at 5600 rpm, T&H jack plate/8"setback/4"rise, and doel-fin,measured by GPS, calculated 100% efficiency speed is 51mph. Again, my apologies for boring everyone to death! Help me on this one! I remember when we would measure a distance, put up some stakes as markers and get out the stop watch! Seems as though we were always finding way to trick our rigs out for more speed. Things are the same these days, I'm glad to say, but the stakes and stop watch (and wet note paper and pencil) have been replaced by GPS , satellites.. etc.. who would have figured? Happy Whalin' .. Clark.. Spruce Creek Navy |
awares
posted 03-24-2001 11:00 AM ET (US)
Clark, I am using a Lowrance X65 to measure the speed. It looks like a paddle wheel assembly. I will be glad to post the GPS results as soon as I purchase one for a comparison.When I have a few more hours on this motor I will also run it and compare the odemeter feature on the X65 to speed. I just do not want to run the motor at top end for a long period of time. I am more than satisfied and I am now concentrating my efforts on other areas of the boat. |
Whalerdan
posted 03-27-2001 10:58 AM ET (US)
I think the answer here is that the prop is "labeled" a 12 but is something steeper. My calculations say it is something like a 16 or so. I don't know that much about props and engines though, so I do not know if it makes sense that a 40 hp motor on a 13 ft boat can swing a 16 prop at 5900 rpm. |
Whaletosh
posted 03-27-2001 04:56 PM ET (US)
Not to fan the flames but I have qutie a bit of experience with Lowrance/Eagle fishfinders. I have found that the paddle wheel speedos aren't all that accurate. I have had cases where the unit was displaying O MPH even though the boat was moving and the paddle wheel was spinning properly. Most pitot pickup speedos are very inaccurate; I don't know why they are even installed. I always demand that they be left off. Some pitot pickup speedos are very accurate; namely those designed and sold to waterskiers. GPS unit provide the most consistent and accurate measurements for most boaters. Their one downfall is at slow speeds. At displacement speeds wind and current will affect the speed measurement. This is because GPS units measure your true speed and direction, not the realtive speed through the water. Keep this in mind when using a GPS for setting trolling speed. Moving 2 MPH upsteam against a 5 MPH current means your lures are moving 7 MPH relative to the water. The fishfinder would read 7MPH if accurate; but the GPS would read 2 MPH. Now you understand some of Einstein's theory of relativity. Sean |
Clark Roberts
posted 03-27-2001 06:58 PM ET (US)
See my comments in "Performance" section under "Performance predictions..." Clark |
2001 13 Sport Owner
posted 03-27-2001 10:15 PM ET (US)
If you use Clark Roberts calculations on Awares 13 Sport you get the following numbers. The boat and engine gross weight = 580 boat + 205 engine = 805 pounds gross weight. He is using a 40HP Engine/805 =.0496894409___________. The square root = .222911285________. Multiply the square root .22291185_________ X 200 = 44.58MPH. When Clark talks about the boats gross weight I am not sure if he means without passengers or not. Anyhow check my math and let me know if you come out with the same calculations. If Clarks formula is correct, then Aware's 13 Sport does achieve speeds of about 45MPH. You also need to take into consideration that he also used a prop recommended by people who guarantee improved performance. I just recently talked to the JT at Nettles Prop shop and he said he could definitely help select a prop that would get max performance for my boat. Any I really like Clarks formula> |
Clark Roberts
posted 03-28-2001 06:17 AM ET (US)
Gross weight is total weight of boat, engine, fuel, battery, accessories, tools, passengers, etc.... the whole works!!!! Clark |
compounder
posted 03-28-2001 12:10 PM ET (US)
I suspect that Allen has just failed to measure his speed accurately.Let's try Clark's formula again: Boat 580# (I think Whaler's published weight is just for the BARE hull, not including seating,console,etc., but we'll use it anyway.) Motor 250# (Mercury uses short-shaft, DRY weight in their figure of 204) Battery & Box 50# Fuel,tank,hose, & fittings 35# SS, 4-blade prop 10# Average adult male 165# Total: 1100# 40hp div. by 1100# = 0.03636 square root of above = 0.1907 200 X 0.1907 = 38.14 mph. I think that even the above estimated speed is high. I had a really screaming 13 with a 60 hp Yamaha that only turned up about 44mph, and that was super-squirrelly! I hope Allen will test with a gps unit and let us know actual speed. Joe |
lhg
posted 03-28-2001 09:07 PM ET (US)
A few observations of my own here. I also use the Lowrance paddle wheel speed/temp sensor as one of 3 speed devices on my Whaler, and checking it against DGPS and a lower unit water pressure speedo, they can run between 5 to 10% high (need to set negative calibration) at speeds of 40mph. So that could be part of the discrepancy.I have also noticed that 4 blade props seem to require reduced pitch. I notice that Merc's new "Trophy Sport" indicates dropping down one inch of pitch relative to aluminium. My guess is that the 12" stated pitch of awares prop is probably a higher EFFECTIVE pitch than 12". I would think the boat could do between 38 and 41, with one person aboard. Merc's prop calculator on mercurymarine.com indicates a theoretical speed, at 1000 lbs, of 41 mph, and 15" 4 blade "Trophy Sport" prop. But I do believe a 4 blade SS prop makes sense here for overall performance, and Mercury seems to agree with their brand new prop offering for the small gear case engines (30-60HP). I am convinced a 3 blade alum is the poorest solution for any hull that will do over 30, and primarily sold only for cost considerations. |
Whaletosh
posted 03-29-2001 05:03 PM ET (US)
I have run 4 balde ComProps for years.Their advise has always been to go to a smaller pitch; so that buttresses what LHG states. Sean |
posted 04-02-2001 08:31 PM ET (US)
I have a Lowrance paddle-wheel speed transducer. It shows excellent agreement with my GPS at low speeds. Above about 20 MPH the paddlewheel begins to read proportionately and consistently higher then the GPS indicator.As Mark Twain said, "A man who owns two watches never knows what time it is." --jimh |
lhg
posted 04-02-2001 09:45 PM ET (US)
To get my paddle wheel Lowrance speed readout adjusted (there is a place where you can adjust calibration positive or negative, by %, on the menu) accurately, I set up the display to show paddle speed and SOG together, making sure I am on open water and not in a current. I have been able to match the readouts almost perfectly. With several of these units experienced, I can say that almost ALWAYS you need to reduce readout by 5% to 10%. After about 40 MPH, accuracy is not so good, as the wheel tends to "float", and the pitot speedo (not much good below 25) and GPS are more accurate.Another reason it's good to get the paddle wheel readout properly adjusted, is that this function also shows miles traveled (distance log). For this to be accurate, the speed needs to be accurate. |
