ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Post-Classic Whalers 1993 outrage 19
Author | Topic: 1993 outrage 19 |
akcabedo |
posted 01-14-2002 02:13 PM ET (US)
anyone know where I can get more info on my 1993 19 ft. outrage, or see original brochures? Seems not to be a very popular year or model!!! |
bigz |
posted 01-14-2002 02:32 PM ET (US)
The 19 was redesigned in '92, loa 18'6",beam 7'2", draft 10", dry weight 1900 lbs.,max wt.cap. one ton, swamped one and half tons, min hp 75, max. hp 150 with 25" shaft, 83 gallons of fuel. You had a couple of layout options available. The console was a new unique design which flipped forward to expose wiring and batteries. What else do you need to know?
lhg |
posted 01-14-2002 04:02 PM ET (US)
See JimH's article on this model in the Rendezvous section, Page 1. Also some pictures. |
posted 01-14-2002 08:04 PM ET (US)
lhg refers to this: http://continuouswave.com/whaler/rendezvous/dayOne.html#outrage-II The 19-Outrage II is a fine boat. --jimh |
akcabedo |
posted 01-15-2002 01:13 PM ET (US)
Thanks guys, what a response!! Actually, there are acouple more things: The boat came with a single mercury 200hp and I wanted to add a second battery, one for starting and one for everything else. Havn´t a clue how to do that! Also, I think I haver a live baitwell under the leaning post, but it only seems to have a drain plug at the base and on the side, how can I make this work? Thanks Adrian |
