Topic: 95' Outrage rocket launchers access
jimb342 |
posted 07-30-2002 08:27 PM ET (US)
Anyone know of an accessory item that attaches to the deck(next to the leaning post/bait tank area) that makes it easier for anyone under 6'6" to access the rocket launchers. Perferably something that blends in. Thanks, Jim
Chap
posted 07-31-2002 10:03 AM ET (US)
Hello, If it is an aluminum post with legs. If you don't need to get a cooler etc. out from under the post or use doors, you could install a flip down step that spans the legs. If cooler etc. are a problem I have seen small permanent "steps" more like nubs screwed or welded to the individual legs. They support a one foot step up. If it is a glass post your could bolt some flip down transom steps to the outside somewhere. Thanks Chap |
Chap
posted 07-31-2002 10:09 AM ET (US)
Here is an example of a transom step. www.bosunsupplies.com/products2.cfm?product=S3630 |
jimb342
posted 07-31-2002 06:15 PM ET (US)
Chap, Great ideas. The flip down cast peice will probably do the trick. Thanks for the tips.I was hoping I didn't have another stump question. Jim |
aubv
posted 07-31-2002 10:34 PM ET (US)
The newer OR's have a fold down foot rest that I know is strong enough to stand on. It is hinged on both sides of the leaning post and is a stainless steel tube with a narrow plastic foot rest which runs along 3/4 of the length. It is held in place when not being used with a plastic C device that the tube snaps into. Folds up out of the way to point that I forget its there sometimes. fwiw |
jimb342
posted 08-01-2002 10:04 AM ET (US)
Aubv, Thanks, I have been meaning to go look at the newer models. Sounds like the proper fix is already been engineered. Strenght of the attachment is a concern of mine. Thanks again, Jim |
jimb342
posted 08-01-2002 10:06 AM ET (US)
Aubv, Thanks, I have been meaning to go look at the newer models. Sounds like the proper fix is already been engineered. Strength of the attachment is a concern of mine. Thanks again, Jim |
