posted 06-30-2003 09:51 PM ET (US)
I just got a new(last years) Montauk 17 and am contemplating adding some equipment and am looking for advice from other owners of similar boats.The single 6.6 gallon capacity gastank it came with is inadequate for other than - very- short trips. I've added a 7.5 gallon Tempo plastic tank, but I figure that eventually I'll need a single 20 to 25 gallon tank. From the other postings it seems like the 24 gallon Pate Plastics fiberglass tank is the way to go, with the least amount of modifications to the seat, bilge access, etc. Does anyone out there know of any better ideas?
I'm wanting to add a baitwell/livewell. From my research, an Aqua World UT13 13 gallon tank seems like a good size, and should have its overflow high enough to drain over the transom. I'm also considering a Kodiak 17 gallon tank, but I'm concerned that it may not have its overflow high enough to work properly w/o raising the tank. In both cases, I'm planning on using a transom mounted pump - I just can't see drilling through that new hull, particularly since at the boat centerline I estimate the hole would be over 10 inches long...
Any ideas about the best place to mount a VHF radio and its antenna would be appreciated. I'm considering putting it on the center console below or to the side of the wheel, facing up, but I'm concerned it may be in the way there. I don't want to install it into the console with a face plate type mount because of losing capacity inside the console and because a faceplate type mount would require a hole cut to its size, which later wouldn't fit anything else... As to antenna, I'm considering a 4' stainless whip, but I'm concerned with interference with the bimini, which is a necessity here.
