posted 10-05-2003 10:40 PM ET (US)
I had to come back to this thread.I put Lenco's on my Dauntless 15 late this summer. The problem I have is that the waters I boat on are pretty rough from boat traffic and I have had a hard time getting the boat attitude adjusted properly to the waves. I can do it by trimming the motor all the way in but then she steers hard and the motor sounds like it is laboring a bit. My wife has a hard time with a hard ride and a softer ride is better for both our aging backs. Hence the trim tab experiment.
So, I installed the tabs after talking with both the Lenco and Bennet guys. I went with the Lenco's just because my console is full enough with two batteries and other stuff, and Lenco's have the simpler installation.
Well, today, I got the chance to finally really evaluate them. Flat calm with moderate boat traffic leaving totally flat water interspersed with wakes. Qualitatively they really improved the ride but I didn't have just the right conditions to test them out. Today I did.
When up they don't take away anything from the top end.
When I trim the motor up to the point where the steering is very neutral (about 25% or so up), The bow may or may not be in the right attitude to take the waves/wakes. With the tabs, I can adjust this until I can comfortably take almost anything without varying the speed much at all.
From full up to full down, the boat never handles unpredictably. Even if I make a fast change in the tabs. It isn't that dramatic.
I had a tendency to porpoise at about 35-30mph. With tabs, this can be completely eliminated. I can also trim the motor way up for low drag and traverse this speed range with no porpoising. When I go out of this range at the top end, I can put the tabs all the way up for lowest drag configuration. If I go to high, a quick zap on the tabs stops any bouncing at all.
The tabs have allowed me to keep a planing attitude at much slower speeds - I can adjust it so that I basically don't get the high nose up plowing attitude. I can pretty much keep the boat on a plane at down to about 14-15mph. Without the tabs, down to 19-18mph. THis is great for handling big chop and keeping the boat riding at fuel saving plane instead of plowing along.
Overall, the ride improved dramatically, the boat has now a ride that more closely resembles a larger boat - maybe 18 -20' instead of a 15'. Not in all respects, but in the softness with which I can take larger chop. It helps hugely to get the nose of the boat down so the fine entry takes the waves. However, I can do this without having to put the lower unit in such a position that the motor is really trying to push the stern up (inefficient), I can keep the prop aimed in the direction of travel (least torque in stering). The engine seems to run with less load ~ 100rpm higher - it just plan sounds better.
Also nice that now the boat attitude and the motor attitude are somewhat decoupled - i.e. the trim tabs have a larger effect on the hull attitude than does the motor trim. This means that I can adjust the hull attitude to the seaway and then adjust the motor trim for easiest sterring or least drag or whatever.
So, I don't know if I totally agree with putting them on a canoe, ;-) but they are a pretty nifty accessory, They have really extended my control over the boat, my planing range, passenger comfort in a range of wave/wake conditions.
Thinking about this in retrospect, I wouldn't have truly been able to understand the difference if I hadn't had the boat for a while first. Understanding how she handles is pretty important for understanding how to make the tabs manage the boat.
So, count me a trim tab fan.
J
