  MONTAUK 170: Garage Fit
Author Topic:   MONTAUK 170: Garage Fit
Marsh posted 11-14-2003 08:18 PM ET (US)   Profile for Marsh   Send Email to Marsh
Any owners out there able to say for sure: will the 2003 Montauk 170 fit into a standard garage with a 7 foot tall door? Or is center console too high? No worries as to width or length (garage is 24 x 36).
Thanks,
Marsh
Knot at Work posted 11-14-2003 08:40 PM ET (US)     Profile for Knot at Work  Send Email to Knot at Work
Sorry, I park my Montauk on the side of my house, behind the fence but... my fence is 6ft tall I do not see the center console when it is behind it....
triblet posted 11-14-2003 10:09 PM ET (US)     Profile for triblet  Send Email to triblet
No such thing as a standard garage door. Mine are a bit
higher than usual, I had one house where they were a bit
lower. My Montauk 167 JUST fits.
Measure your door accurately. Then find an M170 JUST like
the one your want (esp antennas and trailer) and measure it.
Check the length too. If the trailer has a long tongue, it
could be more than 24'
Moe posted 11-14-2003 10:31 PM ET (US)     Profile for Moe  Send Email to Moe
What Chuck says is true. The door itself is usually 7'0" but the frame it backs up to is less. And how much less varies a lot. Measure from the floor to the frame, and make sure the bottom of the door is fully above the frame when it's opened. Not all are.
With a trailer hitch that puts the trailer level, I'd guess a 170 is about 6'10" or so.
Also keep in mind you can gain an inch or so by airing down the trailer tires.
Moe
tabasco posted 11-15-2003 08:00 AM ET (US)     Profile for tabasco  Send Email to tabasco
Should have no problem just measure your height and width when the door is open.
Jimm posted 11-15-2003 10:26 AM ET (US)     Profile for Jimm
No problem going into my garage with 7 foot door.
chaimemet posted 11-15-2003 10:18 PM ET (US)     Profile for chaimemet  Send Email to chaimemet
I have a continental swing tongue model trailer with a 90hp 4 stroke. The rig fits into my 20' garage with 3" to spare. height is not a problem.
drmwvr posted 04-05-2005 10:46 AM ET (US)     Profile for drmwvr  Send Email to drmwvr
Does anyone know the 2005 trailer width?
Thanks,
Clay
Speedo66 posted 04-05-2005 12:58 PM ET (US)     Profile for Speedo66  Send Email to Speedo66
Another thing to check is how level the driveway is just outside the garage. If there is an upward or downward angle, it may affect the height you are able to put into the garage because of the angle it will cause the trailer to assume.
high sierra posted 04-05-2005 11:35 PM ET (US)     Profile for high sierra  Send Email to high sierra
Depends on your speed when you go into the garage. High Sierra
fishinchips posted 04-06-2005 10:15 PM ET (US)     Profile for fishinchips  Send Email to fishinchips
my garage is double wide, but the height is a little shy of 7'.
Montauk 17 and a Montauk 170 can fit inside.
When I had the montauk 17, i had a removable tongue on the trailer.
When I got the montauk 170, i had a swing tongue on the trailer.
jimh posted 04-06-2005 10:37 PM ET (US)     Profile for jimh  Send Email to jimh
[This two year old thread was revived. Now closed.]
