  Cold Starting Merc 90 4Stroke - Montauk 170
Author Topic:   Cold Starting Merc 90 4Stroke - Montauk 170
4WHALERS posted 11-17-2003 09:00 AM ET (US)   Profile for 4WHALERS   Send Email to 4WHALERS
I am having a terrible time cold starting the 90 4S. I have to keep cranking,..cut off,...cranking,...cut off,....cranking,..cut-off. The bulb is pumped hard. It's almost as if the cold start auto-choke is not functioning? Can you manually choke the the 4S? Also, can you see the choke working (or not) with the engine cover off?
Any thoughts?
Barney posted 11-17-2003 11:00 AM ET (US)     Profile for Barney  Send Email to Barney
Turn the key on for 30 seconds, then crank. This warms up a device that allows more fuel to the carbs. Jim
4WHALERS posted 11-17-2003 11:42 AM ET (US)     Profile for 4WHALERS  Send Email to 4WHALERS
Thanks Jim. I'll give it a try this weekend. It really was not a problem this summer but now every time I try and start it 30-40 degrees, it really does not want to start and keep running.
Was this something mentioned in the owners manual? I must a read right over it. Thanks again.
Barney posted 11-17-2003 11:44 AM ET (US)     Profile for Barney  Send Email to Barney
4WHALERS, Its buried in the manual. I read it several times before it clicked. It has worked for me. Let us know how it works in the colder climate. Jim
4WHALERS posted 11-17-2003 01:25 PM ET (US)     Profile for 4WHALERS  Send Email to 4WHALERS
Thanks Again,...I'll give it a go this weekend. I'll let you know.
Thanks again.
