posted 02-20-2004 03:33 PM ET (US)
I am in the process of planning my install of a 24 gallon pate tank in a new Montauk. I have a couple of questions for those that have already installed a Pate on the 170.1. How do you secure the two mounting blocks in the aft section of the tank/RPS. After looking at my wood diagram, it appears that there is wood for the two forward and two side blocks, but NO wood behind the RPS. Is there a way to secure the blocks without wood?
2. How did you set up the fuel line? I was think about either a male quick connect right from the tank (leaving the existing connection on fuel line), or running the line directly to the tank using a 90 degree elbow (which I am having a tough time finding but I know they exist). The quick connect would be easier, but I don't know if there will be enough clearance for the male quick connect under the RPS.
3. Has anyone put anything under the tank before installation (such as dri-deck or some other type of mat?) or just rest the tank on the deck?
Sorry if I am over analyzing this thing but I have never done any type of mod/maintenance on a boat and just have first time jitters. Thanks.
