  Karavan trailer tire pressure
Author Topic:   Karavan trailer tire pressure
Whalen posted 03-04-2004 10:05 PM ET (US)   Profile for Whalen
I cannot find the correct tire inflation pressure for my 2004 MT 170 Karavan trailer. Can any one help?
LHG posted 03-04-2004 10:09 PM ET (US)     Profile for LHG
If they are marked Load Range B tires, 35#
If Load Range C, 50#
If Laod Range D, 75#
Most good trailer tires are Load range C or D.
Chuck Tribolet posted 03-04-2004 10:23 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
The Goodyear trailer radials under my Montauk don't have a
letter load range. They do have a maximum inflation pressure.
I'd suggetst 5-10 pounds under the max.
jimh posted 03-05-2004 01:24 AM ET (US)     Profile for jimh  Send Email to jimh
I have never seen a tire yet that didn't have maximum pressure ratings molded into it, usually in the form of
MAX LOAD XXX LBS AT NNN PSI
The general sense here is you inflate the tires to the maximum rated pressure when cold--very cold, as in first thing in the morning cold. Then as Chuck says, maybe back off a pound or two ( or 5?).
I have always wondered about this situation:
If a tire is inflated to maximum pressure when cold, should the pressure be checked again when the tire is hot? And if so, should the pressure then be adjusted (usually lower) when hot to conform to the maximum?
Jimm posted 03-05-2004 10:16 AM ET (US)     Profile for Jimm
Inflate cold to the amount on the tire wall as Jimh says, and leave it. If for example, it says 900 lbs @ 35 psi then the tire will support 900 lbs at 35 psi - not 34, 33 or anything else. That is what got Ford's Explorer in trouble; they tried to lowert the pressure for better ride and handling and lost weight carrying ability.
