  Kicker weight limits info needed on 170 Montauk
Author Topic:   Kicker weight limits info needed on 170 Montauk
MantyMonty posted 04-17-2004 09:34 PM ET (US)   Profile for MantyMonty   Send Email to MantyMonty
Up until yesterday, I was going to purchase a 6 hp kicker for my 04' 170. Today I got a good price quote on a new 03' Johnson 8 hp. 4 stroke, two cyl. I have a question as to this motor being too much transom weight for the 170. Has anyone mounted a similar engine on a 170, and are the results satisfactory? This long shaft Johnson/Bomb. weighs 83 lbs. I plan on making a move on this Johnson on Monday if the weight isn't too much for the transom. Any input will help my decision.
Thanks.
kamie posted 04-17-2004 09:52 PM ET (US)     Profile for kamie  Send Email to kamie
Max engine weight for the 170 is 410#
I believe your classic 90HP come in at 303#
that leaves you 107# to play with.
So with 83# kicker plus oil and other stuff you should still be under the max.
AQUANUT posted 04-18-2004 06:06 AM ET (US)     Profile for AQUANUT  Send Email to AQUANUT
Got a question for ya to consider....why would ya want a johnson sittin next to your new mercury?....
if it price issue...consider the fact that johnson went under in 1999 left alotta people hangin....
there is a new mercury fourstroke kicker on the way ...a 8hp and a new 9,9hp...lighter than the yamahas..and they are light.....ifin ya new 2 stroke whelp a classic yahmaha 8 is prob the most dependable.....btw...I work at a honda/mercury/yamaha and boston whaler dearlership....
p.s. hope it not a fourstroke johnson.....we are also a johnson/erude dealer too....
this is my personal opinion.....not that of the dealership I work for...be advised
MantyMonty posted 04-18-2004 09:32 AM ET (US)     Profile for MantyMonty  Send Email to MantyMonty
Now that you say it, I do remember seeing the light model Mercs coming out sometime in the summer of 04'. It certainly would be a better match seeing black with black on the back. I would assume the new Merc. 8 is a 2 cyl.so vibes shouldn't be an issue. Do you have any insight when the light models are coming out? Thanks for the reminder.
Barney posted 04-18-2004 10:13 AM ET (US)     Profile for Barney  Send Email to Barney
They don't look like they cost anymore than the old style either. They are in the West Marine catalog now. Jim
Joe Kriz posted 04-18-2004 01:36 PM ET (US)     Profile for Joe Kriz  Send Email to Joe Kriz
Aquanut,
It sounds like you work for River Marine on Crater Lake Hwy on the outskirts of Medford..??
Johnson/Evinrude (OMC) was purchased by Bombardier.. Parts are still available for the older engines but Manty says he is thinking about a 2003 model which is being manufactured by Bombardier now... The 8HP and below Johnson 4 Strokes are made by Bombardier.. The 9.9 and above 4 Strokes are made by Suzuki with the Johnson name on the cowl.
I do agree that matching engines on any boat look better but that is just in the eye of the beholder..... Anything will work as long as it is under the Max weight. (and runs good of course).
The new Merc 8 HP 4 Stroke looks like it might be a good choice if you want to stay with the same manufacturer and have matching color engines.
"8HP, 84lb 20" Shaft Merc 4 Stroke - Lightweight - 5326855 - 1F08211DK
Only $1,849.00 USD"
MantyMonty posted 04-18-2004 02:35 PM ET (US)     Profile for MantyMonty  Send Email to MantyMonty
The Mercury lightweight is black and red where as my 90 2 stroke is black and blue trimmed (Saltwater series). So they wouldn't match perfectly either. The price I got on the 03' Johnson was 1575.00. I thought it was a pretty good price, but I haven't checked a whole lot.
Joe Kriz posted 04-18-2004 02:40 PM ET (US)     Profile for Joe Kriz  Send Email to Joe Kriz
Manty,
The price listed above for the Merc was out of West Marine.... I'm sure if you shopped around, you might find a better price...
Joe
seasicknes posted 04-18-2004 06:05 PM ET (US)     Profile for seasicknes
If you have the 170 montauk with a 90 four stroke. The motor weight is 386 pounds. Recommended max weight for the transom is posted by whaler being 410 pounds.
That leaves only 24 pounds left.
figure you have to mount a bracket also. So thats more weight.
Ken
MantyMonty posted 04-18-2004 10:21 PM ET (US)     Profile for MantyMonty  Send Email to MantyMonty
I do have the 2 stroke 90 Merc. As Kamie mentioned it weighs in at around 303 lbs. The 8hp. 2005 lightweight Merc weighs around 84 lbs. That leaves me some room for the bracket, oil, prop and nuts and bolts. If 410 lbs. is indeed OK to operate at, I probably will go with the light model Merc.
Divedog posted 04-19-2004 01:29 PM ET (US)     Profile for Divedog  Send Email to Divedog
I'll throw in my 2 cents. I've ordered a '04 170 with a two stroke. From the research I've done, I'm leaning towards a 6 HP 4-stroke Merc. I believe it weighs in at 55lbs. I'd like to have a quite trolling motor while the noise of a 2 stroke doesn't bother me while running. The two grand I saved on a the 2-stoke 90 can be applied to the kicker. Plus I can pull the kicker off when I head to the lake for a water skiing weekend.
What type of a mount are you considering? I'm thinking about having a fixed mount fabricated out of aluminum. I need to get the boat before I can get serious about it though.
Matthew posted 04-19-2004 03:55 PM ET (US)     Profile for Matthew  Send Email to Matthew
Divedog,
Check out Tanner Manufacturing out of Bellingham, WA.
Matt
Divedog posted 04-19-2004 05:00 PM ET (US)     Profile for Divedog  Send Email to Divedog
Matthew,
Thanks! You saved me a bunch of research and design. That was an awesome tip. I've seen the brackets on the Oak Bay charter web site. That's where I got my motivation to have a part custom fabricated. I know some good metal shops here in Seattle but if someone has already done the design that will save a lot of time and money.
Thanks again.
Joe Kriz posted 04-19-2004 05:10 PM ET (US)     Profile for Joe Kriz  Send Email to Joe Kriz
It is always nice to include links so other people can view what someone else is talking about..
Either:
http://www.tannermfg.com/tannermfg.htm
Or:
This way everyone will be up to date...
Thanks,
Joe
Divedog posted 04-19-2004 05:22 PM ET (US)     Profile for Divedog  Send Email to Divedog
Just checked out the site and made a quick call. These guys seem like pros. Like most quality purchases, you get what you pay for. It's just under $500 for the solid bracket shown on their web page. After reading some old threads on this site, it sounds like a worth while investment. There are some folks who have been disappointed the cookie cutter brackets sold at chain stores.
bobeson posted 04-19-2004 07:04 PM ET (US)     Profile for bobeson  Send Email to bobeson
I put a 6hp merc four-stroke on my 170 and hated it. The dealer installed it with a Garelick moveable bracket on a "custom" stand-off mount. The engine vibration was bad to begin with, and was amplified by the POS Garelick bracket. The whole setup was terribly insecure and seemed liable to fall off while trailering or motoring in anything but lake conditions. Fortunately the motor was stolen off my boat a few weeks after I got it, so that headache went away - I was actually relieved to lose a $2k piece of equipment, if you can believe that.
While I still had the motor, I spent a lot of time staring at the kicker clearances required to tilt it up and decided that a fixed bracket would be difficult to accomplish with that motor. Before you decide on a fixed bracket, make sure that the clearances required by your particluar kicker motor will be achieved. Note that the Tanner website mentions a number of Whaler models that their brackets are designed to work with, and the Montauk is not listed among them.
If I were to get another kicker, it would probably be a two-cylinder model mounted to a very-well-engineered fixed bracket that allows extended operation (including trailering) with the kicker motor tilted up. I think I would probably also want to figure out a good way to steer the kicker from the helm. For trolling I was using my main outboard as a rudder, but as an emergency get-home motor I'm concerned that the drag created might have rendered progress into a strong headwind unacceptable.
Divedog posted 04-20-2004 10:36 AM ET (US)     Profile for Divedog  Send Email to Divedog
Bobeson,
Thanks for the input. I read your comments on a previous thread. That's part of the reason I am considering a fixed mount. According to the guy at Tanner I talked to, they do have a Montauk bracket, it's just not listed on the site. They also make custom brackets. Before they fabricate they request several photos of the application in order to make sure all the clearances are met. I'm hoping that the fixed mount will cure the vibration problems you encountered but I won't know until I try.
As far as steering goes, they sell connecting rods that run between the motors so you can steering the kicker from the helm. They have ball bearing joints at either end so that each motor can be independently in an upright position and still function.
skred posted 04-21-2004 08:20 AM ET (US)     Profile for skred  Send Email to skred
Couldn't the bracket posed here: http://continuouswave.com/whaler/reference/bracket15AuxMotor.html
for 15 Whalers be adapted or modified? It certainly is strong enough, decent looking, and significantly less expensive. If I were to try it, I'd mock up a plywood version, attach the motor to it and put it up against the transom to determine the fit, and when I got it satisfactory, get a quote from someone local to fabricate it. Just a thought....
whaler1234 posted 02-19-2005 03:18 AM ET (US)     Profile for whaler1234  Send Email to whaler1234
I am interested in installing a 4 stroke kicker for my 2004 170 w/ the 90hp 4stroke.
* Whaler tech support advised that the transom will support weights above the 410lbs (which is about the weight for the wet 90 w/ ss prop). The factory tests were conducted with this configuration.
Has anyone installed an 8 or 6hp 4 stroke on their 170?
Considering an 8hp will add over 100lbs w/ the mount, I would like to use the lightest 4 stroke ava. Would 6hp or even a 5hp 4 stroke sufficiently push the boat safely home.
Thanks in advance.
oahuwhaler posted 02-20-2005 02:43 AM ET (US)     Profile for oahuwhaler  Send Email to oahuwhaler
Whaler 1234,
Just installed a 6 hp Nissan 4 stroke kicker on my 170, GPS reads 4 mph top speed not the fastest but,in open ocean here in Hawaii it will get me home.Also its runs a little rough but,suits my needs.We have only the Coast Guard if we get in trouble so this outboard really does give me peace of mind.
erik selis posted 02-20-2005 04:18 AM ET (US)     Profile for erik selis  Send Email to erik selis
oahuwhaler,
Do you have any pictures of that setup? We would like to see them if you do.
Thanks,
Erik
Rich M posted 02-20-2005 11:54 AM ET (US)     Profile for Rich M  Send Email to Rich M
I considered a kicker for my 170 but was concerned about starboard list. For the guys that have them installed, how does the boat sit/ride/handle with 80+ pounds hanging off one side?
bigjohn1 posted 02-21-2005 07:53 AM ET (US)     Profile for bigjohn1  Send Email to bigjohn1
Whaler1234, since this is only a kicker, why waste nearly 100lbs on an 8hp when you can get a classic Merc 15 at the same weight? I realize its a 2-stroke and you probably want to avoid the hassles of a separate fixed fuel supply. Consider though if you boat in off-shore waters, an engine that propels you to 4mph in descent conditions is going to have problems keeping you going once the seas kick up - been there done that.
whaler1234 posted 02-21-2005 09:24 PM ET (US)     Profile for whaler1234  Send Email to whaler1234
Bigjohn1,
You're right, the classic 15 is only 4lbs heavier than the classic eight. I am still researching what would be the best hp rating for my '04 170. Your comment on the 4mph in rough seas adds to my growing list of questions on kicker motors for the '04 170.
1) Is 4mph from a 6hp kicker enough motor?
2) Montauks hull speed is 7mph, what motor can I achieve this with?
3) Is 84lbs + the 17lb "fulton" bracket too much weight on the corner (leading to porpoising as stated from BW; also promoting the chances of the 170 flipping over in rough conditions when I lean over the rail while fishing)
4) Is the fulton bracket and kicker going to vibrate excessively? (i.e. the bracket is weak or rickety; or the 1 cylinder too harsh?)
bigjohn1 posted 02-22-2005 07:43 AM ET (US)     Profile for bigjohn1  Send Email to bigjohn1
Whaler 1234, I don't totally understand your question,
"Montauks hull speed is 7mph, what motor can I achieve this with?"
If you are attempting to get 7mph out of a kicker, and Oahuwhaler is getting 4mph out of an 8hp, I'd think a 15 2-stroke will give you 8-10mph in fairly calm water but this is only a guess. This is one situation where I would prefer the power of a 2-stroke over a 4-stroke and I would be propping that thing down so it was screaming right at the upper limit of its intended rpm range in calm water pushing a 170. The real test of that kicker is bringing you home when the seas are rough and you are bent over trying to tiller-steer a fairly large boat. Think ahead on how you intend to steer it. I think (but am not 100% sure) that you can either buy an extension handle for tiller steering or buy the linkage kit and use the boat's installed steering system for the kicker.
Your question on whether or not the 170 will handle safely with all the extra weight on one side I think is truly the $64K question. I can tell you this if it will help...I weigh 230 and my main fishing buddy weighs over 275 and on the occasion where we both step to the side (like when reeling in/gaffing a fish), I still feel safe in the boat.
My thought is that you would want to devise a counterbalancing plan on the other side with some of your fuel tanks and other gear. Since you would be "chugging home" at very low speed and would not have the benifit of an electric trim/tilt, arranging your gear properly for a balanced load would become that much more important. Also factor in your added body weight to the stern area as you would likely be sitting on a cooler way back aft when tiller steering.
whaler1234 posted 02-22-2005 01:08 PM ET (US)     Profile for whaler1234  Send Email to whaler1234
Bigjohn1,
From what I gathered and deduced, I believe hull speed is the max speed I'll be running at prior to planing. I may be wrong. There was mention that trying to run a motor smaller than the minimum will not get you on plane, therefore, the higher hp will net the same speed as the kicker. The factor being that planing takes that much additional hp to get the hull out of the water.
After searching these forums, it seems that the 8hp was a popular choice, followed by the 6 and 9.9.
kingfish posted 02-22-2005 03:29 PM ET (US)     Profile for kingfish  Send Email to kingfish
And hull speed for a Montauk 170 is 6 MPH, not 7 MPH.
MantyMonty posted 02-22-2005 04:05 PM ET (US)     Profile for MantyMonty  Send Email to MantyMonty
I just confirmed with my local marine sales shop that my order was placed last Friday for a T9.9 high thrust Yamaha four stroke kicker. I am going to mount it on my 04 Montauk in spring. The tipping possibility will be off set by the weight of the portable gas tank and bucket 1/2 full of 8 pound trolling balls. My 65 lb. son and the bucket-o-balls didn't list it noticably last year, so it won't be a problem. I will be 20 lbs. heavier though due to the CMC-PT35 power tilt unit on the transom. I am going to connect the two motors with with an EZ steer or front connecting rod. That will keep me in the center of the boat where I belong. My son and seldom fishing wife will be on the bow seat also contributing to counterweight. The high thrust should push the 170 fine in Lake Michigan waters. Have a good day!
