  Pate fuel tanks, taxes, and liquid teflon
Author Topic:   Pate fuel tanks, taxes, and liquid teflon
BemidjiWhaler posted 04-18-2004 05:46 PM ET (US)   Profile for BemidjiWhaler   Send Email to BemidjiWhaler
OK. I paid my taxes, started an enjoyable thread, and bought the Pate tank also.
A question: In articles I've read, "Liquid Teflon" is recommended for installing and sealing any brass connections to the tank. Is "Liquid Teflon" the same as using a "Loktite" type substance?
Another question: Will regular teflon tape hold a fuel seal on a boat tank?
Thanks again,
Smith, D. F. USMC 1966-1972
AQUANUT posted 04-19-2004 05:32 AM ET (US)     Profile for AQUANUT  Send Email to AQUANUT
I'll try to explain it as it was explained to me
I personally use teflon tape available at any napa store....
there are two kinds of teflon tape....the white and the yellow...
preferably the yellow is designated for use with pretroleum products and the white is used in conjunction with water primarily
as far as liquid teflon being put in the same basket as the various types of locktites.....they are not the same product with different intended uses. technically speaking
AQUANUT posted 04-19-2004 05:39 AM ET (US)     Profile for AQUANUT  Send Email to AQUANUT
P.S. 1974-1978 and 1980-1986 US NAVY!
guess how much of it was "at sea"?
fyi thanks to the us navy..I know what the eye of an hurricane at sea is like..three times over....ah yeah 1 cyclone in the indian ocean...thot we were gonna sink..and the creme de la creme.....a 75 foot wave over the bow...in the cyclone......yippie-cy-yi-ay!
seasicknes posted 04-22-2004 08:58 PM ET (US)     Profile for seasicknes
3M Pipe Sealant with Teflon.
* Seals Threaded Fittings
* Prevents Leakage
* Protects against corrosion
* Repostionable for 48 hours
For use on metals only. Not suitable for use on plastics.
Suggested uses: Stainless steel fittings, oil pressure sending units and sensors, oil and coolant lines, fuel fittings, rear axle fil plug, brake and power steering fittings.
