  Pump Out Switch Wiring 1999 OUTRAGE 23
Author Topic:   Pump Out Switch Wiring 1999 OUTRAGE 23
VMG posted 04-26-2004 08:25 AM ET (US)   Profile for VMG   Send Email to VMG
I'm replacing the key switch for the waste pumpout system on my 1999 OUTRAGE 23. There are two wires that connect to the switch -- one has a fuse in-line and the other does not. They are the same color (brown), and unmarked. I assume one goes to the connection 'B' for battery and the other goes to the position marked 'I' for ignition. Can anybody help? No Whaler place help nearby.
aubv posted 04-26-2004 08:52 PM ET (US)     Profile for aubv  Send Email to aubv
VGM,
I can't look at mine for a couple of weeks but would offer this advice, use a volt meter and check for continuity with the key in the off position and then again in the on position. Should show continuity only in on position. Check the switch before attaching the wires. If you still need help in a couple of weeks let me know.
jimh posted 04-26-2004 08:58 PM ET (US)     Profile for jimh  Send Email to jimh
The normal practice in wiring is to place the circuit protection (fuse) ahead of the disconnect (switch). From this you could infer that the lead to the switch with the fuse is from the battery. Of course, you could verify this in about five seconds with a voltmeter.
jimh posted 04-26-2004 09:03 PM ET (US)     Profile for jimh  Send Email to jimh
[This article has been edited to remove non-standard abbreviations, particularly ones invented to substitute for the model names of Boston Whaler boats. Also, year designators have been re-written in four digits, instead of two digits and an apostrophe. I find that there is little value in attempting to save a key stroke or two of typing with the result of obscuring the information content of an article with these unnecessary abbreviations. I have repeatedly asked that articles do not use abbreviations for the year or for the model names of the Boston Whaler boats. That request is again repeated. Compliance would be greatly appreciated.]
Ed Stone posted 04-26-2004 09:26 PM ET (US)     Profile for Ed Stone  Send Email to Ed Stone
I'll look on Tuesday the 27th and see how mine is
set up.
Ed Stone
VMG posted 04-27-2004 06:53 AM ET (US)     Profile for VMG  Send Email to VMG
Jim,
For those who aren't familiar with your repeated requests, it might be beneficial to have a reference for your standard posting protocols. Although I see that folks figured out that the non-standard OR was actually code for OUTRAGE and that '99 was actually 1999, I certainly don't want to offend the moderator's sensibilities. If I've missed that listing, perhaps you can point me in the right direction.
Ed Stone posted 04-27-2004 09:17 PM ET (US)     Profile for Ed Stone  Send Email to Ed Stone
Vmg,
My waste pump out was not done at the factory.
The wires going to the kill switch are white,and
there is no in line fuse.
Ed Stone
jimh posted 04-28-2004 12:55 AM ET (US)     Profile for jimh  Send Email to jimh
No pblm use abbreviations just make hrd 2 rd art. & obscure info contnt + hw to srch for OR (outrage) & not get "or" wrd (conjunction0
C wht I mean?
