  smart tabs for 170
Author Topic:   smart tabs for 170
seasicknes posted 06-08-2004 09:56 PM ET (US)   Profile for seasicknes
anyone running smart tabs (automatic trim tab system) on there 170 ?
No wires, no hydraulics. Suppose to be really easy to install.
AQUANUT posted 06-09-2004 07:09 AM ET (US)     Profile for AQUANUT  Send Email to AQUANUT
SMART TABS..no wires, no hydraulics...somewhat useless
thrown some of these in the trash before.
they will only minimally assit in time to plane, they are of ZERO use in leveling the vessel from port to strbd., vice vera,
if you are trying to trim boat fore-to-aft..stick with
engine tilt, prop change, or a bolt on fin for your anti-cavitation on engines lower unit assy.
Moe posted 06-09-2004 08:50 AM ET (US)     Profile for Moe  Send Email to Moe
Whenever tabs are providing lift, they are creating drag. Real tabs can be set to provide neither when lift isn't needed, while "smart tabs" are always creating both. At low speeds it's applied to lift the boat stern, as speeds increase that goes away, and it's then applied to compress the springs. The springs wouldn't compress if there was no lift (and hence drag). Their advertising is misleading in this respect.
Moe
JohnJ80 posted 06-10-2004 09:46 PM ET (US)     Profile for JohnJ80  Send Email to JohnJ80
I second the sentiment that real trim tabs are better than these things. The Smart Tabs are not all that cheap and you get so-o-o much more with the real thing.
J
