ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Post-Classic Whalers Cleats for 2002 Montauk 170
Author | Topic: Cleats for 2002 Montauk 170 |
osillator |
posted 06-15-2004 12:36 AM ET (US)
I really need to add the rear cleats to my 2002 170. I bought the first one in this area and I think its the only thing the factory goofed up. Has any one gotten Whaler to provide cleats for a model that did not have them originally???? I heard a rumor on this thread that it did happen. I will be glad to install them here if they would provide them. I am looking for suggestions...thanks in advance. |
Knot at Work |
posted 06-15-2004 10:05 AM ET (US)
I filled out my questionaire on my 2003 170 Montauk Whaler provided me a rebate check for the cleats and labor so in otherwords they installed them for me I was Impressed and Whaler earned my loyalty for a lifetime and myabe two generations in my family as my boat will become my sons |
BemidjiWhaler |
posted 06-15-2004 10:17 AM ET (US)
The 2003 Montauk doesn't have rear cleats either. I emailed Whaler and they recommended using the same cleat as the one on the bow, and mount them just behind the rear rail. I can get you the part numbers if you need them, or they can be gotten at www.whalerparts.com. Go to the FAQ section first to download the necessary plug-in to view the drawings. Also, there is an old thread somewhere on this site that discusses this topic. |
sportroyalwulf |
posted 06-15-2004 03:33 PM ET (US)
The 2004 150 sport has added cleats to the interior of the transom. This is one of the few changes. I don't have pictures. I have installed these newer cleats on my 2003 150 sport. They replace the existing tie downs with a unit containing the cleat on one side and a tie down/tow eye on the exterior. The cleats are of a good size and cost about $70 from whaler. No drilling. They may work on the montauk. |
Moe |
posted 06-15-2004 04:40 PM ET (US)
Is that $70 each or $70/pair? Anyone else have these cleats you could post a picture of? -- |
sumnerdav |
posted 06-15-2004 05:06 PM ET (US)
The ones that I purchased from the dealer were about $150 for the pair of oem cleats. Don't know what you would do without them. |
Maximus |
posted 06-15-2004 06:30 PM ET (US)
The 8 inch 'yacht cleat' available from West Marine works very well. Not as robust as the bow cleat but they look like they belong. They cost much less than $150...maybe $20 including hardware. |
Barney |
posted 06-15-2004 06:52 PM ET (US)
http://myweb.cableone.net/barney9014/images/17/10.jpg This is a Whaler cleat, and I got a check for $61 and change from Whaler to pay toward the pair I installed. JimB |
Knot at Work |
posted 06-15-2004 09:31 PM ET (US)
Barney same with me Jim, They (Killinger now Marine Max) installed them and then BW called me to ask me about the survey I filled out. They sent me a check reimbursing me for the Cleats, Labor and then some. They did good. |
Barney |
posted 06-15-2004 09:34 PM ET (US)
Knot, You were the first to find this out and alert everyone at the time. I owe you a beer or three. JimB |
AQUANUT |
posted 06-15-2004 09:39 PM ET (US)
I am well aware of the cleats used on the 150/130's.....quite unique...never seen them anywhere else in the industry...I'll post a picture for you tomorrow barney, JimB
Barney |
posted 06-15-2004 09:50 PM ET (US)
Aquanut, I been over you boat's pictures with a fine tooth comb my friend on several occasions. I saw your 2004's cleats mounted on the inside of the rail a while back. I like that factory installation location better. JimB |
Knot at Work |
posted 06-16-2004 12:05 AM ET (US)
Same with me. I think they actually added mounting areas in the hull for the 2004 models to be able to take that cleat in that position. I like it under the rail it allows the area to be used to stepped into etc.... |
Joe Kriz |
posted 06-16-2004 12:13 AM ET (US)
Boston Whaler has never made their own Cleats that we know of. Does anyone know who made these particular Cleats? In the past, Wilcox Crittendan (sp) and Perko have made many products for Boston Whaler and recently, Wilcox Critteden cleats were passed on and sold to Perko. Let's try and not guess here but the facts only. |
InHerNet |
posted 06-16-2004 10:27 AM ET (US)
I contacted my dealer and they in turn contacted Whaler about the cleats. Whaler sent the dealer the cleats to install on my 2002. All at no charge! How many other boat manufactures would do this? Not many! Don |
Moe |
posted 06-16-2004 11:50 AM ET (US)
The problem with the 130/150 cleats on the inside of the stern eyes is that forward-running spring lines are still going to rub on the gelcoat on the top of the gunwale. An aft running spring line from the bow cleat is lifted off the gel coat by the rub rail, so it isn't a problem forward. Now that I have rod holders mounted fairly low on the side rails, I'll just tie off the aft spring line on the rail, and the stern line from the stern cleats. -- |
RioRaft |
posted 06-16-2004 03:31 PM ET (US)
Osillator, Boston Whaler provided and installed the cleats on my 2003 170. They match the front cleat exactly, but about 1 inch smaller. Mounted about two inches behind the rear rail mount. |
AQUANUT |
posted 06-16-2004 11:59 PM ET (US)
the cleats on my 2004 montauk 170 are the exact same as some I ordered from Port Supply.....a marine distributer here in the Pacific Northwest.
hardensheetmetal |
posted 06-17-2004 05:31 PM ET (US)
I am curious if the interior cleats used on the 130/150 are the same as the ones I recently saw on the 110. They take the place of the lifting eye on the interior of the boat, where the ski eye bolts through the transom. If these are the same, they are really trick, very heavily made either stanless or chromed brass. These are especially nice, as they do not reqire any back up plates or screws into the boat. Dan |
mikeyairtime |
posted 06-17-2004 05:46 PM ET (US)
The 2004 has the cleats inside of the side rails. This location keeps them from snagging, a lesson I (and apparently Whaler) learned through experience. Look at any nice sportfish boat and the cockpit will be cleat/snag free. |
BemidjiWhaler |
posted 06-23-2004 09:24 AM ET (US)
I emailed Boston Whaler last week concerning rear cleats for my 2003 Montauk. I received an email reply today that was extremely satisfactory. What an incredible company! Also, I would have never known about this without this website. Thanks jimh. Dave |
Maximus |
posted 06-25-2004 12:35 PM ET (US)
Question: I purchased a 2003 Boston Response from Whaler:
