  Stains in Gelcoat
Author Topic:   Stains in Gelcoat
BemidjiWhaler posted 06-21-2004 05:45 PM ET (US)   Profile for BemidjiWhaler   Send Email to BemidjiWhaler
Just trailed the 2003 Montauk back to Minnesota after having several weeks of too much fun around the Gulf Islands National Seashore off the coast of Mississippi. It is a gem of a place, but I digress from the topic...
I have noticed "ever" so slight stains on the boat right at the waterline. The stains appear as vertical streaks. I tried a mild detergent and elbow grease, then two different types of marine "Cleaner/Wax." The stains are still there. I would like to remove them before I give the entire craft a good coat of wax and go have more fun somewhere else.
Any advice would be appreciated. The information and entertainment I have gleaned from this forum is priceless.
Dave
SteviLad posted 06-21-2004 05:56 PM ET (US)     Profile for SteviLad  Send Email to SteviLad
Try West Marine Hull Cleaner......I've had very good luck with that product.
Jarhead posted 06-21-2004 06:17 PM ET (US)     Profile for Jarhead  Send Email to Jarhead
You can always try the old reliable tough stain remover Barkeepers Friend.
LHG posted 06-21-2004 07:35 PM ET (US)     Profile for LHG
As mentioned above, the key to getting rid of yellow hull staining is any product containing Oxalic acid as the active ingredient.
TomG posted 06-21-2004 08:46 PM ET (US)     Profile for TomG  Send Email to TomG
Bar Keeper's Friend (which contains oxalic acid as Larry mentioned) will do a great job of removing stains on gelcoat. But be careful, because it is mildly abrasive. It will scratch (or dull) the gelcoat if you use it too vigorously.
Tom
Plotman posted 06-22-2004 11:26 AM ET (US)     Profile for Plotman  Send Email to Plotman
Get Zing. It's an acid cleaner that you spray or roll on with a pain roller. Then flush with LOTS of water. Can be kind of hard on galv trailers. At a minimum wet the trailer down ahead of time and rinse immediately.
Gets rid of waterline stains better than anything.
BemidjiWhaler posted 06-22-2004 01:37 PM ET (US)     Profile for BemidjiWhaler  Send Email to BemidjiWhaler
Thanks for the responses. I'm off on an oxalic acid quest. Gosh I love this site.
Dave
LHG posted 06-22-2004 02:26 PM ET (US)     Profile for LHG
I use Starbrite's Instant Hull Cleaner, as it a non-abrasive liquid. Put into a generic spray bottle. You can either spray directly onto hull (a little goes a long way, and you have to watch for drips on the trailer) or spray into a rag, and wipe on.
Swellmonster posted 06-24-2004 10:24 PM ET (US)     Profile for Swellmonster  Send Email to Swellmonster
Mary Kate on and off hull cleaner. Try dilute it 50% and put in spray bottle, wate a few and enjoy, then rewax!
