Topic: Towing weight of an Outrage II
prm1177 |
posted 06-25-2004 07:55 PM ET (US)
Can anyone out there give me the approximate towing weight of an Outrage II 17 with an Optimax 135? I can add up the parts: boat-1700, engine-431 (dry), trailer-780. That puts the boat dry with no rigging around 3000 lbs. Will an SUV with a rated 5000 lb towing capacity be sufficient if I ever wanted to tow the boat.
RJM
posted 06-25-2004 09:54 PM ET (US)
Paul, I think you are very close with the tow weight. That is what I got when I weighted my rig on a certified scale. I tow my Outrage II with a Toyota Tacoma double cab with the max towing capacity of 5000 pounds. It seems to do a good job, but it feels a little small and I seldom go more than 60 mph and try to give myself lots of room to stop. I am taking my boat to Mexico in two weeks and I am planning to tow with an empty fuel tank and fill up close to Bahia De Los Angeles. Three thousand pounds seems to be a safe weight on a vehicle that is suppose to tow up to five thousand pounds. Of course, I would rather tow with a larger rig, but I like getting twenty miles to the gallon with a four-wheel drive when I am not towing. Take care,Bob |
prm1177
posted 06-26-2004 11:59 AM ET (US)
Thanks, Bob. Post some pictures of the Baja trip. I thing the other NorCal owners would like to see them. |
fjjpal
posted 07-02-2004 11:27 PM ET (US)
I have a Johnson 115 on mine and tow with a 1997 toyota 4 runner with 5,000lbs of towing capacity and it handles it fine. Have a good 4th. Frank |
LHG
posted 07-08-2004 05:32 PM ET (US)
Whaler advertized the boat weight at 1900 lbs. |
posted 07-10-2004 07:59 AM ET (US)
In general, the rated towing capacity for a vehicle is figured with the vehicle in its lightest possible configuration. Anything added to the vehicle counts against the towing capacity. That includes:--fuel --passengers --any optional equipment For example, if you order your vehicle with the optional roof rack that weighs ten pounds, that reduces the towing rating by ten pounds. If you put a wife and two kids in the car, their weigh reduces the towing capacity. For this reason, it is prudent to figure that a vehicle which is rated for, say, 5,000 pounds of towing capacity, can only tow a boat/motor/trailer load of around 4,000 pounds maximum under normal circumstances. |
