  2005 Nantucket Fuel System
Author Topic:   2005 Nantucket Fuel System
JoJo posted 04-19-2005 10:50 AM ET (US)   Profile for JoJo   Send Email to JoJo
Does the Nantucket come with an external Fuel/Water separator filter? If not, should I have one installed? Taking delivery soon to splash the boat; however, the dealer owes me money (strange, eh?) and I wonder if I should have one installed before putting the boat in. The engine is a 2005 150-HP OptiMax. Any and all thoughts are welcome by this inaugural Whaler novice. Thank you.
DeepSouthWhaler posted 04-19-2005 11:39 AM ET (US)     Profile for DeepSouthWhaler
The OptiMax engines do not require an external separator. I believe it has something to do with restricting fuel flow. These engines have an internal separator/filter that you usually change once a year.
bsmotril posted 04-19-2005 12:31 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
Though Mercury says you don't need one, I've had Racor filters in front of a pair of Merc 135 OptiMax egines for 7 years with no problems whatsoever. You can find a Racor at almost any little outboard shop of any brand, or any marine chain store around the country whereas a Merc OptiMax separating filter might be a bit harder to come by. The added separator is only restrictive if the fuel flow is great enough for it to be a factor. On the 135 Opti, there is not enough flow to matter. The fuel burn for the 150 Opti is within 2GPH of the 135, so a Racor likley won't hurt a 150 either.
BillS
JoJo posted 04-19-2005 05:01 PM ET (US)     Profile for JoJo  Send Email to JoJo
I wish to thank you both for your prompt response(s)...thinking of installing the [RACOR] as a redundant system. Thanks again.
bsmotril posted 04-19-2005 09:43 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
Mine came from the whaler factory with the Racor filters in front of the Optis, so go figure. Maybe they did not read the manual either. BillS
jimh posted 04-20-2005 08:25 AM ET (US)     Profile for jimh  Send Email to jimh
[Administrative post]
