  cooler seat for rage 15
Author Topic:   cooler seat for rage 15
john anderson posted 05-03-2005 04:23 PM ET (US)   Profile for john anderson   Send Email to john anderson
I am looking for a cooler seat for a rage 15, preferably all white, any ideas?
where2 posted 05-03-2005 10:59 PM ET (US)     Profile for where2  Send Email to where2
Resident Rage fixer-upper here... The story goes that the original owner left my cooler on some Bahama Island after consuming the numerous beers inside it. When I bought my Rage, the second owner threw in a cooler with wheels (with the wheels removed!). Needless to say, that was a sloppy fit!
So, in the search for the "right" cooler, we've determined that the 54Qt Igloo is too large (fore-aft) for the existing chocks. The next smaller (36Qt or 48Qt, I don't remember) was OK fore-aft on the chocks, but needs the chocks moved apart about 1" side to side.
Obviously, Igloo changed the dimension of something... Probably adding more foam than was originally in the appropriate sized cooler...
I'll let you know the size after my next visit to the boat.
john anderson posted 05-04-2005 01:59 PM ET (US)     Profile for john anderson  Send Email to john anderson
where2 - thanks for checking. My boat never had a cooler so there are currently no chocks in the floor. I suppose I could use any cooler that fit the space but am wondering if I can't get an original what size or style might work best?
Larry posted 05-09-2005 12:47 PM ET (US)     Profile for Larry  Send Email to Larry
John,
I still have my rigid winter cover on my Rage so I can't get to the cooler but I hope to this weekend and will check the fit with what I believe is the same igloo cooler purchased at our local supermarket for 16$. The cushion may be a lot harder to replace.
Larry posted 05-09-2005 11:58 PM ET (US)     Profile for Larry  Send Email to Larry
Couldn't put it off any longer so took the cover off tonight. The orginal igloo is a 40 gal model. My supermarket special is a 48 gal igloo which is the same height and depth but three inches too wide to fit in the orginal chocks.
