  2000 90 hp Ficht compression test procedure
Author Topic:   2000 90 hp Ficht compression test procedure
PoundnPoi posted 07-23-2005 06:37 PM ET (US)   Profile for PoundnPoi   Send Email to PoundnPoi
What is the compression test procedure for a 200 90 HP Evinrude Ficht engine.
PoundnPoi posted 07-23-2005 07:04 PM ET (US)     Profile for PoundnPoi  Send Email to PoundnPoi
The engine is a year 2000 90 hp Evinrude Ficht.
On carb'd Johnson/Evinrude engines I would connect my push button switch to the starter solenoid, key switch off, all plugs removed, throttle wide open, and test each cylinder with the remote engine switch.
Will using this procedure harm any component in the Ficht 90hp?
