Topic: Weight of 1995 Montauk
Tygh1 |
posted 08-05-2005 10:21 AM ET (US)
What is the dry weight of the 95 17' Montauk? I have seen several different weights and need to know the weight so I can estimate towing capacity for my vehicle.
jimmy c
posted 08-05-2005 11:29 AM ET (US)
According to my Boston Whaler origional catalog the weight is 900 lbs to figure your towing weight you will need the weight of: boat motor fuel tank full battery radio,fish finder,compass anchor with line life jacketts,flair and first aid kits bimini top covers and then 100lbs for mics. trailer add weight of winch,tongue jack and side guildes. check the owners manual of your tow vehicle for towing capacity and to see if you will require brakes on the trailer. good luck. |
Buckda
posted 08-05-2005 12:25 PM ET (US)
If you have a vehicle with a Class II receiver hitch and 3,500 capacity, you should be fine with this boat.That means smaller/midsize SUV (Not the miniatures) a full-size sedan with the above capacities. You're going to be towing at less than #2,500, however the #1,000 cushion is nice, because it allows you to fill the vehicle up with people and gear too. |
