  boston whaler outrage 180
Author Topic:   boston whaler outrage 180
hansjm posted 09-05-2005 12:07 PM ET (US)   Profile for hansjm   Send Email to hansjm
Hi,
anyone who can tell me if it is possible to put a 225 Etec Evinrure behind this boat ? and what would happen if I do ?
Regards
Hans
hansjm posted 09-05-2005 12:23 PM ET (US)     Profile for hansjm  Send Email to hansjm
SORRY !!!!!!
it has to be the whaler 180dauntless !!!!
Hans
Joe Kriz posted 09-05-2005 12:48 PM ET (US)     Profile for Joe Kriz  Send Email to Joe Kriz
Hans,
The 180 Dauntless is rated for 150hp maximum.
I know you are into speed so you could go to the E-Tec 200hp for the same weight.
The E-Tec 150, 175, and the 200, all weigh the same at 427 lbs for the 25 inch shaft.
If you try to put on a 225hp, it weighs 524 lbs... Almost 100 pounds more on the transom. I think that might be too much weight. If you are thinking about putting on the 225, you might as well go to the 250hp for the same weight...
Good Luck and don't forget to wear your crash helmet with all that speed... :-)
hansjm posted 09-06-2005 07:42 AM ET (US)     Profile for hansjm  Send Email to hansjm
So do I iunderstand correct that you think the boat can handle the weight and power but you care mainly for my safty. correct ?
my main concern is that the boat is not out of balance with the nose high in the sky and that I dont loose the engine becouse the whole stern broke off
Hans
