  What Whaler is it? 1992 21' WA?
Author Topic:   What Whaler is it? 1992 21' WA?
ds posted 03-31-2006 04:03 PM ET (US)   Profile for ds   Send Email to ds
There is a 21' whaler walkaround currently for sale, 1992...it looks similar to a Conquest, but not quite. Any ideas what model it is? I can't find specifications or a catalog online anywhere to check. Thanks for any help, looks like a sweet boat.
Tom W Clark posted 03-31-2006 04:12 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Well it's probably a 1992 Whaler 21 Walkaround.
http://continuouswave.com/whaler/cetacea/cetaceaPage49.html#49-08
LOA - 21' 0"
Beam - 8' 6"
Draft - 13"
Hull weight - 2600 pounds
Max. weight capacity (persons, motor and gear) - 2550 pounds
Swamped capacity - 6000 pounds
Persons capacity - 11 persons
Maximum HP - 250
Minimum HP - 150
Engine shaft length - 25"
Fuel capacity - 92 gallons
Backlash posted 03-31-2006 05:30 PM ET (US)     Profile for Backlash  Send Email to Backlash
If that's the one (High Note) at MarineMax in Stewart it looks like it's in pretty good shape from the pictures. Also a good price. Wonder what "low hours" mean?
Check the link in my profile for more info on this model.
Mambo Minnow posted 03-31-2006 06:46 PM ET (US)     Profile for Mambo Minnow
I looked at that boat in November. Be forewarned...it fell off the rack in WILMA and they had to do gelcoat repair on port side of hull.
But even before this misfortune, the boat did not on inspection look well cared for in my opinion. It sat exposed on a lift thru four hurricanes. There was mildew smell in cockpit, delamination of veneer in cuddy from moisture and wet marine plywood under that. The anodes also looked completely corroded on the Yamaha. The owner has moved back to CT and stuck Marine Max with the sale.
In short, I think it took alot of moisture damage. It was too far gone for me, but that's a personal decision. Just thought I would save someone a long trip, if this did not meet their expectations. I like to look out for fellow CWers.
ds posted 03-31-2006 09:30 PM ET (US)     Profile for ds  Send Email to ds
You guys rock! Thanks for your help, and the specs and also for the condition report...it did seem too good to be true; guess I'll pass.
