Topic: Bilge pump switch on 170 Montauk
wbullwin |
posted 08-08-2006 01:22 PM ET (US)
I posted another topic which now raises another question. The 3 position switch on the console works on "ON" and does its thing on "Auto" but never shuts off the pump totally on "OFF". Has anyone else had this problem? Is there a way to rewire? I'm told that if I shut the pump off (I assume in the "OFF" position, I can leave the boat in the water overnight with the plug out and rain water will simply not acummulate, nor will the pump run.
InHerNet
posted 08-08-2006 05:05 PM ET (US)
Try cleaning the pump. Sounds like the float on the pump is stuck. |
InHerNet
posted 08-08-2006 05:08 PM ET (US)
Sorry, misread your problem. I would change out the switch. |
posted 08-08-2006 08:58 PM ET (US)
[This article was originally posted to THE GAM but has been moved to this discussion area because this discussion area is specifically designed to discuss this topic.] |
