  2004 DAUNTLESS 220: Loose Fasteners
Author Topic:   2004 DAUNTLESS 220: Loose Fasteners
Milepost43 posted 10-12-2006 09:33 PM ET (US)   Profile for Milepost43   Send Email to Milepost43
While cleaning my 2004 220 Dauntless today, noticed that two of the six bolts holding the front fishing pedestal base were loose. After I checked, I just pulled them out with my hand. These are bolts, not wood type screws. Got home too late to call [the Boston Whaler factory]. Do these have some type of nut embedded in the fiberglass/starboard? Thanks.
HawaiianWhaler posted 10-13-2006 08:48 AM ET (US)     Profile for HawaiianWhaler  Send Email to HawaiianWhaler
The "wood" locating diagram for a 22' Dauntless shows 1/2" thick phenolic 3"x7" under the rectangular forward fishing seat pedestal base. That's a strong indication that the 1/4-20 flat head fastener went into a hole threaded into the phenolic. If you can't tighten up the fastener then the threaded phenolic would seem to be stripped. If you can gain access to the underside of the phenolic then you can simply use fender washers and nylock nuts to secure the loose fasteners. If there is no access you can either use a threaded insert such as a helicoil, or alternately you can try plugging the hole with marine-tex, then redrill and retap new threads. Good luck.
Milepost43 posted 10-13-2006 10:38 AM ET (US)     Profile for Milepost43  Send Email to Milepost43
Talked to BW. Guy thinks mostly likely thing is phenolic was not in correct location and tapping was only into fiberglass. Makes sense since only the far right screws were loose. He is contacting my dealer. Probably means I will have to take boat out and put on trailer to have them fix it.
Milepost43 posted 11-13-2006 04:19 PM ET (US)     Profile for Milepost43  Send Email to Milepost43
Took my 220D to shop on Fri. Fixed today. Problem was that factory had drilled 2 of 6 holes for threaded bolts that hold front fishing seat pedestal at an angle. Factory stripped threads on installation. Dealer redrilled and tapped next size larger. Phenolic plate was in correct location.
