  210 Outrage Raw Water Washdown
Author Topic:   210 Outrage Raw Water Washdown
jsgrise posted 01-11-2007 11:44 PM ET (US)   Profile for jsgrise   Send Email to jsgrise
Hey guys!--We just bought a 2002 210 Outrage with a 200 Optimax on the transom. We also have the deluxe leaning post with livewell. I think it will be a great fishing boat! The only problem is that I can't find the raw water washdown hose? Do you guys have any idea?
Thanks a lot for your help! I wouyld really appreciate.
Sebastien
mfclapp posted 01-12-2007 07:12 PM ET (US)     Profile for mfclapp  Send Email to mfclapp
Good possibility that you don't have one.
My 1999 20' Outrage didn't and I had to add it. If you need any tips drop me a line.
Tight Lines
Big Red
TRAFFICLAWYER posted 01-12-2007 09:46 PM ET (US)     Profile for TRAFFICLAWYER
You left it at West Marine.
jsgrise posted 01-13-2007 12:00 AM ET (US)     Profile for jsgrise  Send Email to jsgrise
Thanks TRAFFICLAWYER you've been very helpfull! I,m asking this because in the Deluxe Leaning post description, I'm suppose to have it. But maybe because my boat have the freshwater washdown option, it replace the raw water...
Thanks Red,
Sebastien
bsmotril posted 01-14-2007 01:41 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
Look for a capped hose outlet in the motor well. To get water out of it, you have to turn the spray nozzle in the livewell clockwise to cut off water flow to the livewell first since they share a pump. BillS
jsgrise posted 01-15-2007 05:59 PM ET (US)     Profile for jsgrise  Send Email to jsgrise
Thanks a lot Bill! I'm glad now I know how it works! But does this work even the freshwater system?
Sebastien
jsgrise posted 01-15-2007 06:15 PM ET (US)     Profile for jsgrise  Send Email to jsgrise
*Even with the freshwater system
bsmotril posted 01-15-2007 08:57 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
They are two completely different systems with their own pumps and different sources. The freshwater has a showerhead. Turn on the pump and press the button on the back of the showerhead to make water flow.
jsgrise posted 01-15-2007 10:16 PM ET (US)     Profile for jsgrise  Send Email to jsgrise
That's the problem. I only have one outlet with the shower head. Did they delete the raw water washdown since I have the fresh water one?
Steve M posted 01-16-2007 08:12 AM ET (US)     Profile for Steve M  Send Email to Steve M
Sebastien,
Unfortunately, I think back in 2002 the raw water washdown only came with the fishing package. I know the current Whaler website shows that the current (i.e. 2007) model year has it with the leaning post, but you can probably dig up the old website with the "2002" package specifications if you want. Go to Whaler.com, click on "My Whaler", then click on FAQs. Scroll down to like the second to last question "How can I view some of the previous boats and specifications that Boston Whaler offered?", and there is a link to a web archive. I think it is better to show you how I got there, then just put the link. I had trouble pulling up 2002 website, but the 2003 version apparently came up, and it only had the washdown with the fishing package. The good news is that adding the raw water washdown is probably not that hard, per other advice you have already gotten. Good luck, Steve
bluewaterpirate posted 01-17-2007 03:00 PM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
I have a 2002 210 Ventura that is built on the same hull as the 21 Outrage. I took some pictures of the plumbing that resides under the transom bulkhead. The fresh water hose & pass thru is located on the Venturas starboard side just aft of the transom door. You helm switches might be a little different than mine but the fresh/raw water pump switches will reside together. As you can see you fill your livewell or choose to close it off so all the water goes to the raw water washdown connection. The only other mod you might have is a freshwater hose inside your console storage compartment. Click on the link below to view the pictures. You can by a hose at any marine dealer to fit on the raw water wd connection.
http://bluewaterpirate.phanfare.com/slideshow. aspx?username=bluewaterpirate&album_id=193247
Tom
fno posted 01-17-2007 06:36 PM ET (US)     Profile for fno  Send Email to fno
Sebastian, if you go to whalerparts.com you will find an excelent drawing of the set up in your exact boat. Tom, I think your Ventura is built on an older 21' Outrage design. In any case, I can take pictures of the exact setup this weekend
bluewaterpirate posted 01-17-2007 09:31 PM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
Yea after I posted that I read the post the way I should have the 1st time. Well I tried.
jsgrise posted 01-18-2007 10:00 PM ET (US)     Profile for jsgrise  Send Email to jsgrise
BWPirate:
Thanks a lot for your time, it's really appreciated even though the layout isn't exactly the same.
On the other hand, FNO, I would REALLY appreciate if you could post some pics of your setup, including the raw water system + the fishbox pump out system. I know I'm asking a lot, but It would be really really appreciated.
Thanks a lot for your hospitality,
Seb
