posted 06-28-2007 07:14 PM ET (US)
Dennis -Read your owner's manual. I'm sure Mercury has an official opinion on the subject.
Most folks here will give you similar advice to this: Flush your motor after every use with freshwater.
Some will give you the following advice:
use an additive like "salt away".
Here's what is important:
Your motor is made of metal. Saltwater corrodes metal, and leaves salt residue when it evaporates. Your motor uses seawater as a cooling agent INSIDE the engine where there is no paint protection for the metal. That water may evaporate during periods of inactivity. Those cooling water passages are fundamental to the health of your engine. Salt crystals don't always dissolve quickly enough in new saltwater to open up blocked passages.
Yep...my advice is to flush her. I believe Mercury even installed a handy flushing port that makes it easy.
Dave
