Topic: Sun Lounge, 19 Outrage
tripletail |
posted 09-13-2007 03:29 PM ET (US)
Is there a way to make the Fishing Package work with the sun lounge.? (Whaler Brouchere said they are not compatible).
Yiddil
posted 09-13-2007 08:14 PM ET (US)
Don't belive that they won't work together. I put one in and it works fine. You just have to do some adjusting by taking out the rod holders and relocating the cooler to behind the leaning post seat. Actually works better that way and gives you a third seat at the stern of the boat.It also gives you like an huge amount of laying down spaace and cupple that witha Bow dodger and its simply a wonderful contraption...see my other posts for pics...in nantucket review.... The install is easy, but the sun lounge is well worth it as its not made of wood, its made out of starboard, fairly thick stuff, and heavy , like 50-60 lbs, then a gorgeous added and custom pillow that goes from where the other one left off all the way to the center consol:) Simply put, its the best thing I put on Das Boat besides the bow dodger:)) |
Yiddil
posted 09-13-2007 08:16 PM ET (US)
http://continuouswave.com/ubb/Forum8/HTML/002889.htmlfor the pics:) |
tripletail
posted 09-14-2007 03:44 PM ET (US)
Thanks for the pictures, it looks like the rod holder might not need to be removed? I don't mind moving the cooler but would like to keep the rod holders |
Yiddil
posted 09-14-2007 04:08 PM ET (US)
You will have to move some if not all of them, but then again just reposition them if you want them there in that spot on the front end of the CC....the point mainly is that the sun lounge will work with the fishing package, you just have to reorgganize some of it to other areas of the Nantuceket/Outrage...Its a fantastic package to add...alas its not cheap, but the fit and polish of the starboard, installl, and cushions are tremendous addition to an already fantastic WHaler:) |
