ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Post-Classic Whalers Steering frozen on Montauk
Author | Topic: Steering frozen on Montauk |
TTWhaler |
posted 04-08-2008 04:08 PM ET (US)
Well, my 2004 170 Montauk with 90HP Merc has a frozen steering. I have read the threads about the non-stainless steel tilt tube. I used WD40 and pounded the rod with a wood block and hammer, it won't move at all! Anyways, I'm considering a hydrallic steering system as the replacement. Which one should I get? Thanks! |
an86carrera |
posted 04-08-2008 07:01 PM ET (US)
Seabob4 has a good deal on the BayStar by teleflex which would work well on that boat/motor combo. Len |
Casco Bay Outrage |
posted 04-08-2008 07:03 PM ET (US)
TT - Try tilting the motor full up and down a dozen times. Many have had success with this technique. C B O |
fisherman |
posted 04-08-2008 07:45 PM ET (US)
When you last greased the steering cable ends, did you have the rod fully retracted into the tube. If not, the cable may have become hydraulically locked. In which case you may have to take it apart to free it up. Just a thought? Ray |
TTWhaler |
posted 04-09-2008 03:41 AM ET (US)
Casco Bay Outrage: It's the inside of the tilt tube and steering rod that's stuck. If I cut the cable on the starboard side, I can slide out the tilt tube with rod attached. So raising and lowering won't do the job, but I've tried that already. =) fisherman: Hmm... I've never greased the cable end. Always just the rod end that's accessible externally. Here's a photo of the starboard cable side. I remove the nut from the tilt tube, after that I am able to turn the steering wheel. The part that's between the aluminum nut and the tilt tube threads, what part is that? The cable? Because the diameter is smaller than the main rod on the port side. Keep the advice coming. If all fails I'll be hacksawing the cable and then taking the tilt tube+stuck rod out. BTW, has anyone replaced their steering cable on a 170? Did you have to remove the motor in order to get the rod into the tilt tube? The cable is so stiff and the rod is so long, there might not be enough room to get the rod in... maybe. (So that's why I was thinking a hydraulic system would be easier to install) |
TTWhaler |
posted 04-09-2008 03:51 AM ET (US)
an86carrera: Thanks, I just emailed Seabob4. |
BlueMax |
posted 04-09-2008 08:17 AM ET (US)
It has also been previously recommended to install a "Steersman Nut" which allows the steering rod and cables to be greased - http://www.steersman.com/html/whatitdoes.html Runs $20 for Anodized Aluminum (Fresh water use) and $30 for Solid Steel. Just another thought. |
Feejer |
posted 04-09-2008 09:30 AM ET (US)
Wow, Does this same type of problem effect the 05 and newer boats? I'm pretty good about lubing up the steering a few times during the season. |
Tohsgib |
posted 04-09-2008 01:41 PM ET (US)
If you have mechanical steering it effects your boat...no matter if a 2005 or a 1925. You NEED to lube it a few times a season. I concur on the grease fitting dealy thingie for $29 in SS. |
Tohsgib |
posted 04-09-2008 01:42 PM ET (US)
PS...you should wipe off the old grease and clean it out with WD40 before greasing t. If you just leep slamming in grease, it will harden and freeze your steering as well and is a REAL biotch to fix. |
Casco Bay Outrage |
posted 04-09-2008 02:05 PM ET (US)
TT - I have been where you are. I would take off the nut on the opposite side (port) and shoot PB Blaster in BOTH sides. Let sit overnight. Shoot it again. Let sit. Try tilting. Tilting does actually turn the steering rod inside the tube. If the starboard side nut is off, the cable will slide on the sheath (black part) but the cable inside the tube is still frozen. If no joy, with both nuts off, bang the cable out from the port side. If you get it to move 6 inches, shoot PB Blaster and then try to get it back in. Work it back and forth. If you can't get it unstuck, apply medium heat along the tube with a propane torch and remove. Cutting the cable should be the last resort. You will still need to drive it out. Regardless of age, if you don't have a steersman nut, you should pull the cable out every fall and re-lubricate it. leaving it out of the tube is also another measure to prevent freezing. C B O
Tohsgib |
posted 04-09-2008 02:17 PM ET (US)
Good points! PS..if you tried to break it lose with the steering wheel, chances are you might have done damage to the helm or cable at the helm if you REALLY yanked on it hard. |
thediscusthrower |
posted 04-09-2008 03:21 PM ET (US)
I had the same issue 3 years ago. I had to use a brass punch, hammer and a can of "Deep Creep" (i.e., Sea Form in spray form) to spray the inside of the tube and free the cable up. I also utilized a set of Vise Grips to wiggle the rod back and forth while pulling it out of the tube. You can also try placing a piece of wood under the skeg and using a floor jack to take the weight/pressure off of the mount where the cable slides. That may allow the liquid to penetrate better. I would also recommend not using grease at all. I installed a special nut which allows lubrication with an oil. Before I installed that, I would use sewing machine oil. I think the special nut and bottle/tubing/oil is available thru Davis and should be in most boat supply catalogs. Bob |
bigjohn1 |
posted 04-09-2008 06:04 PM ET (US)
Steering cable replacement on the 170 Montauk requires engine removal. Break out your wallet but while you’re at it, spend the extra $20 on the Steersman Nut as recommended by Blue Max. If you have money burning a hole in your pocket, go ahead and purchase the hydraulic steering but IMO, its way overkill in a ’17 boat with a 90 hp outboard. A more cost effective approach would be to simply keep up on the periodic lubrication of your tilt tube. Once you install the Steersman though, periodic lubrication will be a snap and your steering will never freeze on you again. |
GreatBayNH |
posted 04-10-2008 09:43 AM ET (US)
Ok, now you all have me worried. I thought I saw on this site a post that recommended storing the steering arm in the tube for the winter to keep it safe from corrosion. Now I'm thinking that's not such a good idea. |
Feejer |
posted 04-10-2008 10:12 AM ET (US)
This is all starting to sound pretty crazy. My brother and I owned a down and dirty older Mako CC for 7 years. Greased the steering maybe once a year and NEVER had a problem with the steering system. I ask again if this is an inherent problem on the Montauk with either the type or certain manufacture they use? |
GreatBayNH |
posted 04-10-2008 10:50 AM ET (US)
I can already predict the replies will be in the area of "nature of the beast" for this type of steering mechanism. That said, when I have my boat de-commisioned/re-commisioned professionally, every year, they lube and make sure the steering is good to go. I've yet ot touch the steering rod in any way but now I'll be a tad more mindful, to pay special attention thoughout the entire season, that's for darn sure. |
Tohsgib |
posted 04-10-2008 11:00 AM ET (US)
No freejer...you siad you greased it once a year, should be good with that. Many people do not grease it at all. |
Feejer |
posted 04-10-2008 12:25 PM ET (US)
Thats a bit of a relief....Thanks |
L H G |
posted 04-10-2008 02:43 PM ET (US)
OK guys, here's the real scoop, from this long time Mercury owner, and although the information is applicable to all engine brand tilt tubes, this is specifically for Mercury powered Whalers. I have used this for 20 years now, and never had a steering ram bind up in the tilt tube, either mechanical steering or side mount hydraulic. First see my post here (3rd one down): http://continuouswave.com/ubb/Forum3/HTML/001901.html The basic problem is the design of the Mercury tilt tube. It's fine when the engine is new, but it is INCREASINGLY UNSERVICEABLE WITHOUT REMOVING THE STEERING FROM THE ENGINE, WHICH ALSO MEANS UN-BOLTING THE ENGINE FROM THE BOAT. Nobody EVER does that on a routine basis, and the steering eventually freezes. This applies whether your engine has a regular, or SS, tilt tube, is a 1970 model or 2008 model. Re-greasing regularly also does not work, as explained below. The problem is that Mercury places the O-ring seal inside the port end of the tilt tube, making it IMPOSSIBLE to replace without pulling the steering ram out of the tube. This is why the 1" thread size STEERSMAN grease zerk nut is needed. You can order it directly from thier website. The MAIN thing it does is put the O-ring gasket out on the end of the nut where IT CAN BE EASILY REPLACED. But for it to work properly, *YOU MUST-MUST-MUST REMOVE THE ORIGINAL MERCURY O-RING JUST INSIDE THE END OF THE TILT TUBE* Then, by simply disconnecting the link arm, you can remove the Steersman from the engine, slide it off the steering ram, clean it, and put in a new O-ring. And with the nut off, now you have some play in the ram where it exits the tilt tube, so you can extend it all the way out, keep it clean, and by turning the wheel back and forth many times, bring new CLEAN GREASE back into the tilt tube. Then re-install the Steersman, and use the zerk to create the grease plug behind it. Now you have a steering tilt tube that will last forever if serviced as needed, which will only take 15 minutes or so. If you are already frozen, I recommend starting fresh with a new SS tilt tube and steering cable. This works so well, and so smoothly, that I am able to steer my ribside Outrage, with 150 Merc, up to 47 MPH, with standard Teleflx QC steering, the cheapest product they make, with 3.0 turns and without the No-feedback feature. Steering is very easy, with no pull, as long as the engine is the trimmed to the "neutral steering pull" position while running. This post should become a FAQ here. |
TTWhaler |
posted 04-10-2008 04:14 PM ET (US)
L H G: So in order for me to install a new steering cable I need to unbolt the motor from the transom? |
bigjohn1 |
posted 04-10-2008 10:15 PM ET (US)
TTWhaler, LHG knows what he's talking about in this regard and was the one who originally educated many of us on CW about the Steersman nut. As I am a fellow owner of a 170 Montauk and was the one who The cable will not come out of the steering tube with the engine installed. The steering tube is situated too close to the rigging tunnel entrance and there is not enough room to work there. Not a huge deal though, simply have the dealer do it for you since they have the hoist and proper lifting equipment to do it safely and correctly. I think the labor charge for lowering the engine and replacing the cable was about $95 for me. I'll spend that any day of the week to avoid wrestling with a 400lb, $8,000 outboard which can potentially fall and seriously hurt someone when this procedure is done at home in the garage. |
TTWhaler |
posted 04-13-2008 12:35 AM ET (US)
The only reason why I want to go with a hydraulic kit is because it might be easier for me to install myself. I like to work on the boat myself if possible. Hopefully a hydraulic steering installation DOES NOT involve unbolting the motor from the transom. If I went with a cable steering, how much in parts would it cost me? Does anyone have the right part numbers for 1) Steering kit |
fishinchips |
posted 04-28-2008 11:45 PM ET (US)
So how come some cable steering is sticking while others are not in there montauks? Ken |
GreatBayNH |
posted 04-29-2008 09:14 AM ET (US)
Hi Ken, I'm no expert but I'd have to guess it comes down to differences in use, maintenance (or lack thereof) and possibly the way it's stored for long periods of non-use (aka winter). -Seth |
swist |
posted 04-29-2008 01:45 PM ET (US)
Just so I'm absolutely clear - if I install a Steersman nut, it will do no good unless I remove the existing original factory O-ring. Can I do this myself, or must the engine be removed? |
GreatBayNH |
posted 04-29-2008 06:12 PM ET (US)
I second the question. I'm not clear on that either. |
Feejer |
posted 04-29-2008 07:49 PM ET (US)
I'll throw my hat in a third the question : ) |
bigjohn1 |
posted 04-30-2008 05:35 PM ET (US)
Yes |
GreatBayNH |
posted 05-01-2008 11:01 PM ET (US)
Just Yes? Really? Was that a joke? I'll make it easier for you. Q: If I install a Steersman nut, will do no good unless I remove the existing original factory O-ring? Q: Can I do this myself? Q: Must the engine be removed? (really the only part I personally was unclear on) |
Casco Bay Outrage |
posted 05-01-2008 11:35 PM ET (US)
The O ring must be removed. You can do it yourself. You do not need to remove the engine from the transom. |
bigjohn1 |
posted 05-02-2008 09:05 AM ET (US)
Take a look at the orientation of the rigging tube (and how the steering cable exits the tube and enters the engine) on the 170 and then compare it to an older Montauk. You have less room to work with on the newer 170 Montauk. The steering cable is not coming out on the 170 Montauk with the engine bolted to the transom. While you can indeed install your new Steersman nut yourself at home from the port side, how is that o-ring going to come off? In my case, I had my engine height lowered to the middle hole because mounting it in either of the top two holes causes the steering cable to be bent at an un-natural angle. This extreme angle (in my case) caused accelerated cable wear and eventual sticky steering. Since the engine was getting unbolted anyway, I had the dealer install a new cable at the same time but had him leave the o-ring off. I then installed the steersman nut at home myself. I suppose if you were determined to try this with the engine attached, you could unbolt the helm, remove the cable from the helm, and pull the cable out from the console. It is still going to be a two-man pain in the butt job and may or may not work ultimately. Since most of us do no have overhead hoists in our garages, its much more practical (and safe) to simply have your dealer remove the engine and start with a new cable, leaving the o-ring off the new cable. I think the labor in my case for the steering cable replacement/engine lowering was $95. If the labor cost was $300-$400, perhaps I would have tried it myself. Note to 170 Montauk owners: If you raise your engine higher than the middle set of mounting holes and you don't have a Steersman nut installed, expect accelerated cable wear. Take a look at how close the rigging tunnel entrance is in relation to your engine. |
