Topic: Mercury 90 FOURSTROKE Veradito Engine Cowling Seal
Andrewdavis34 |
posted 04-16-2008 10:08 AM ET (US)
Hi all. I have a 2008 170 Montauk that has a 90-HP Mercury [FOURSTROKE]. I am wondering if anybody has had any salt creep under the engine cowling and get onto the engine itself. I have to take the cover off all the time after use to inspect for salt intrusion. Most of the time there are salt deposits on the lower two spark plug covers as well and sometimes a little puddle of water at the rear of the engine.Has anybody found a product that can be used to improve the watertightness of the engine cowling or come up with any other solutions?. Thanks, Andrew
tombro
posted 04-16-2008 11:01 AM ET (US)
I routinely give the rubber [gasket] a light glaze of vaseline so that my Verado is protected. So far, so good. I also spray the engine with Mercury Corrosion Guard several times a season, just in case. |
Feejer
posted 04-16-2008 11:34 AM ET (US)
http://www.corrosionx.com/ |
bigjohn1
posted 04-16-2008 05:49 PM ET (US)
Inspect your engine cowling gasket closely and its placement on the engine cowling. The usual complaint about Mercury engine cowlings is that they seal so well, they are too diffcult to get off. Your experience is the exact opposite. I have four years and 550 hours of saltwater use in one of the harshest saltwater environments on earth and no salt and or saltwater intrusion on the block of my Mercury. |
aubv
posted 04-16-2008 05:51 PM ET (US)
Andrew--The symptoms you describe are what I witnessed on our 225-HP Optimax.This many not be what you think it is, it may be a poppet valve [malfunction]. Have you noticed a slight decrease in the water temperature? I would suggest you pull off the cowling, start the engine, run up to over 2,000-RPM, and look for water on the lower portion of the engine block. |
bluewaterpirate
posted 04-16-2008 10:53 PM ET (US)
If I get water intrusion into my 225 OptiMax it's because I've backed down on a fish in the open ocean. The water comes in thru the latch insets on the back left and right lower motor assembly. It really takes alot of wave action up on the motor cowl to make this happen. I've had my Opti in service since August of 2002 and have 2783 hours the motor, all in saltwater. The cowl design and seals have protected it in all kinds of weather and sea conditions. My OptiMax has stayed dry in heavy rain, snow, and copious amounts of salt spray. Here's what the motor looks like after all these hours on the ocean. http://bluewaterpirate.phanfare.com/slideshow. aspx?username=bluewaterpirate&album_id=347992§ion_id=474715 Tom |
Ferdinando
posted 04-17-2008 12:59 PM ET (US)
Tom:I purchased a new Montauk 190; I'm awaiting delivery on it in July. I was concerened that it has a Mercury on the back as I'm not a big fan of these engines, however looking at yours after 2700 hrs makes me feel a lot better. Thks for calming my fears for the moment. Fred |
bluewaterpirate
posted 04-17-2008 01:26 PM ET (US)
Fred--I was not a Mercury Opti fan when I purchased my Ventura but its what came on the boat. Over the last 6 years I've grown to really like & trust Merc, their products, and innovations. It took me about a year to gain confidence in my Opti a confidence that now permits me to take my Ventura 50 miles offshore. I've been very happy with its performance and gas consumption numbers. The motor has been a true work horse. Mercury learned their lesson well from all the problems they faced when the Opti series was first released. Good luck with your new Montauk and enjoy the memories it will give you! Tom |
contender
posted 04-17-2008 03:07 PM ET (US)
bluewater, have to give you kudos your engine looks brand new, do you spray/coat it with anything? thanks |
Ferdinando
posted 04-17-2008 03:15 PM ET (US)
Tom: Again thks for the feedback, although I will have a FOURSTROKE 115 on the back of my Montauk have you had any issues with your engine in all the time you have used it. And as Contender ask's whats your secret for keeping that engine so new looking..............Fred |
bluewaterpirate
posted 04-17-2008 03:45 PM ET (US)
I use Corrosion Block and lightly spray my engine twice a year. After each use, I take the cowl off a conduct a visual inspection ([obssesive] in this regard) just to make sure everything is in it's place. Lightly clean the engine as necessary. I change the lower unit oil every 100 hours, the water pump impeller every 500 hours, remove the prop every year and grease the prop shaft, change the oil filter and fuel water seperator once a year, and replace the plugs every 300 hours.I had a compressor bearing issue in mid 07 (heard the dreaded chirp). Took it to my mechanic, who found that indeed I had a bad bearing in the compressor. He called Merc who asked him for a serial # of my compressor. Within 5 minutes Merc told them to replace the compressor under warranty, they're reason for authorizing this was the original compressor was from a lot that had had previous bearing issues. At that point my Opti was 1 month out of warranty and Merc knew that (I had the 5 year extended warranty) but they choose to cover it under warranty. To say the least, I was a happy camper, saved $850.00 replacement/labor costs. That's the only issue I've had. The current Opti looks nothing like my 2002 it has been altered and improved on. |
Andrewdavis34
posted 04-17-2008 10:02 PM ET (US)
Thanks to all who have replied thus far. Today at lunch I took the cowling off and was able to inspect the rear latching mechanism. Upon inspection I noticed that there were salt crystrals immediately around the latch and the SS bolt head was starting to rust on a few of the corners. I applied some boeing 303 spray to the latch as well as light coat of greese. As far as latching sequence is concerned does it matter what side is closed first either the front first then back or vise versa? In the information that I have from Mercury it says to latch the rear first then the front. I have up until now been latching the front then the back. I can't see why this would affect the sealing of the engine. If somebody can explain I'd appreciate it. Thanks, Andrew |
bigjohn1
posted 04-18-2008 09:39 AM ET (US)
Hey Tom, that is a damn nice looking power head for a 6-year old saltwater engine with over 2,700 hours!Andrew - did you look closely at the placement of the gasket strip on the bottom cowel halves. Just makes sure nothing has been pushed out of place. I like very much and have used the "glen e" procedure with great success over the years. If Glen is lurking, he can chime in and clarify but here is what I do: About once every three months I remove the cowel and spray the block down with a 50/50 mixture of water and saltaway from a spray bottle. I put my garden hose nozzle on "mist" and mist/rinse the saltaway mixture off. I do this procedure in the morning and leave the boat out in the hot sun for the rest of the day so all water dries off. Leave the cowel off to facilitate drying. At the end of the day when its completely dry, I spray the powerhead down with Mercury "Corrosion Guard" spray. There are many other products which will work equally as well though. Even if you get a little salt on the engine, this procedure will ensure none of it starts to corrode any of the base metal. Use common sense when spraying around rubber products, especially around your timing belt. I can't over-emphasize careful inspection of gaskets on the top and bottom cowel though. aubv mentioned that it might be your poppet valve. To my understandig, your engine does not have a poppet valve but I could be wrong. Can anyone clear this up? I thought the only Mercury outboard with a poppet valve was the Optimax? |
aubv
posted 04-18-2008 10:41 PM ET (US)
bigjohn1,You maybe right that there are no poppet valves on the 90HP. I do not know one way or the other. I do have a 225 Optimax that had a poppet valve fail. The salt deposits Andrew described reminded me of what I saw on my engine before discovering the problem with the poppet valve. Sorry for any confusion. |
Andrewdavis34
posted 04-18-2008 11:40 PM ET (US)
Hi all,What is a poplet valve?? What does it look like? Again boat is a 2008 170 Montauk with a 90 HP Mercury [FOURSTROKE]. Andrew |
posted 04-20-2008 12:33 AM ET (US)
While I think it is good to hear about the excellent seal of the engine cowling on the older Mercury OptiMax motors, Boston Whaler stopped selling the Mercury OptiMax motor with their boats, so I am certain that the motor Andrew is asking about is the new Mercury FOURSTROKE Veradito (to clarify since the name FOURSTROKE has been used with three different models).Also it is good to hear about the sealing of the cowling on four-year-old motors, but they can't be the FOURSTROKE Veradito, which just came out about a year ago. Yes, in my own first hand experience the cowling on older Mercury motors was very difficult to remove due to a tendency for the fit of the gasket material to be very tight. Also the gasket material used to be a vinyl-like material. It seemed to have a tendency to stick to the cowling and the lower pan, making the separation difficult. Vaseline, or more properly vaseline petroleum jelly, is a petroleum grease material. There are some reports that application of vaseline or any petroleum grease is harmful to rubber and is to be avoided. An alternative is to use a water-based lubricant like K-Y jelly. Of course, since you're trying to keep water out, a water-based grease may not be the best choice either. Another alternative is silicon. However, silicon can cause damage to some of the sensors used in modern engines, and you should be careful about spraying it near the engine. As a general precaution, I suggest you do not get silicon spray into the air intake path. A poppet valve is a valve of a particular shape and generally operated against a spring, and in outboard motors they are common in the cooling system where they respond to changes in the PRESSURE (not the temperature) of the water flow. Typically the function of the poppet valve is to remain closed until the water pressure increases to a certain stage. This usually occurs with increasing engine speed, when the cooling demands increase. Therefore the poppet valve provides a way for the engine cooling system to increase the cooling with increasing engine speed. Mercury has re-styled many of their engine cowlings, so it is speculative to apply the performance of the old ones to the newest ones. In my experience the engine cowling on the FOURSTROKE Veradito can be removed much more easily than the older cowlings. Perhaps this is related to the intrusion of water into the power head. Or, perhaps Andrew's engine has a leak in its cooling system. It will be good to get that resolved. |
Andrewdavis34
posted 04-20-2008 07:27 PM ET (US)
Jim,Thanks for you explaining the function of the poplet valve. I have a hard time beleiving this is the cause of the water intrusion. Once again I only have salt creep around the rear latching mechanism on the engine side and salt crystrals on the the latch itself on the cowling. Occasionally there is salt on the the second from the top cylinder cover where the spark plug goes, but this is very superficial. I have since reversed the latching sequence for the front and rear latch. Hopefully this modification in latching sequence will fix my problem. Will try it out next weekend and let everybody know what I find out. Andrew |
Feejer
posted 04-20-2008 07:57 PM ET (US)
Are you getting an unusual amount of water kicking up on the engine from your transducer? |
