ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Post-Classic Whalers Ventura Freshwater problems
Author | Topic: Ventura Freshwater problems |
paddyt111 |
posted 07-31-2008 03:49 PM ET (US)
As I explore all if the workings of my Ventura I am having problems getting my Freshwater shower to work. I have turned on the switch at the helm and nothing. No noise from the pump at all. I am deducting that it may be a broken pump or a blown fuse. I'm not quite sure how to diagnose either possibility. Any thoughts from the BW panel of experts :) Incidentally, when I use my raw water ...the pump pops into action. No mistaking the noise. Pat |
TRAFFICLAWYER |
posted 07-31-2008 09:36 PM ET (US)
Water in the tank? Circuit Breaker? Ck 12vdc at pump? Shower head? |
paddyt111 |
posted 07-31-2008 10:12 PM ET (US)
Thanks for weighing in.. - Yes, water tank is full (although a good question) - Ruled out the shower head as there is no action at the pump. - Not sure how to check the circut breaker? By this do you mean a fuse? Is it located behind the console? Is it straight forward to determine if the fuse is blown? 12vdc at pump....I'm not quite sure what you are referring to. |
tombro |
posted 08-01-2008 09:11 AM ET (US)
A simple start and effective fix is a check of the filter, which you access by opening the starboard panel under the rear seat. It screws off the lower right part of the pump, and may be clogged. I need to clean mine several times a season for what looks to be algae. If this is clear, a mechanic can diagnose the pump itself easily. |
bluewaterpirate |
posted 08-01-2008 10:33 AM ET (US)
Here's a couple items to look for. Image-4892322-39889114-2-WebSmall_0_b29f44178a38228251d62fad38c65cb8_1 Picture of the pump under the stern bulkhead. It's easy to trouble shoot. Tom |
bluewaterpirate |
posted 08-01-2008 10:35 AM ET (US)
Repost of image 1. |
paddyt111 |
posted 08-01-2008 10:39 PM ET (US)
Guys, I'm heading down to the boat in the morning. I'll try some of your suggestions. Thanks, Pat |
